Toyota Alternator #629554
03/03/10 12:23 PM
03/03/10 12:23 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Was considering trying this on my 383. Who has the brackets and wiring schematic for this setup? I know the alt has a 3 prong connector and apparently eliminates the VR.
Grandma always said I had "hands of gold"!
Re: Toyota Alternator [Re: CHRGR69] #629555
03/03/10 12:37 PM
03/03/10 12:37 PM
the house on the left.
cogen80 Offline
cogen80  Offline
Re: Toyota Alternator [Re: CHRGR69] #629556
03/03/10 02:42 PM
03/03/10 02:42 PM
AndyF Offline
AndyF  Offline
Most of the larger Mopar parts vendors carry that kit. 440Source, Mancini Racing, Hughes Engines, etc.
Re: Toyota Alternator [Re: CHRGR69] #629557
03/03/10 02:54 PM
03/03/10 02:54 PM
make sure you file a lawsuit against toyota when it causes your accelerator to stick at wot lol.
Re: Toyota Alternator #629558
03/03/10 03:49 PM
03/03/10 03:49 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Re: Toyota Alternator [Re: CHRGR69] #629559
03/03/10 07:15 PM
03/03/10 07:15 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I have it on my small block, works great. Make sure to not run the sense wire just back to the alt. It confuses the regulator.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Toyota Alternator [Re: FurryStump] #629560
03/04/10 05:32 PM
03/04/10 05:32 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Ditto... I picked the alternator and brackets as a kit from Mancini's a few years back for my Eddie headed 360. The 60 amp alternator charges dramatically better than the 73 amp round back I was running. Power seats, locks, windows, an MSD ignition, and subs are no problem.
Also, as said before, run the sense line back to the battery.
Re: Toyota Alternator [Re: MarkZ] #629561
03/04/10 08:56 PM
03/04/10 08:56 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Mine is overcharging and now I think I know why I have the sense wire just over to the starter relay
Thanks guys
BTW I used the AR Engineering mount kit with the AR motor plate too it all fits perfect
Gus
64 Plymouth Savoy
Dana 60
Re: Toyota Alternator [Re: fourgearsavoy] #629562
03/04/10 10:37 PM
03/04/10 10:37 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
That should be fine as long as its on the live side of the relay.
Re: Toyota Alternator [Re: Stanton] #629563
03/05/10 12:12 AM
03/05/10 12:12 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Same place mine on the starter relay. Works fine
Re: Toyota Alternator [Re: FurryStump] #629564
03/05/10 02:33 AM
03/05/10 02:33 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Mine holds a constant 14.5v at the battery, is that overcharging?
Re: Toyota Alternator [Re: ademon] #629565
03/05/10 02:36 AM
03/05/10 02:36 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
About Ideal...
Re: Toyota Alternator [Re: 1_WILD_RT] #629566
03/05/10 11:37 AM
03/05/10 11:37 AM
minnesota
Kirby Offline
Kirby  Offline
minnesota
Is this really worth doing? I have tons of stuff in my Cuda project. A/C,P/Seats, amp, electric fuel pump, line lock,H1/H4 headlights on relays, etc. I have done the Mad conversion, so I've eliminated the poor original connections, and figured running the headlights on relays would help "free" up some power for the rest. Stock alternator-
Re: Toyota Alternator [Re: Kirby] #629567
03/05/10 11:39 AM
03/05/10 11:39 AM
In the twisties
RokketRide Offline
super gas
RokketRide  Offline
super gas
In the twisties
It's lighter, more compact, and I'm told makes more juice at idle than the old unit.
Re: Toyota Alternator [Re: RokketRide] #629568
03/05/10 11:51 AM
03/05/10 11:51 AM
AndyF Offline
AndyF  Offline
Yep, the Denso units put out a bunch more amps at idle than the Mopar design. I switched over to the Denso unit (Toyota 4Runner) several years ago on my car and the difference was quite noticeable.
Re: Toyota Alternator [Re: fourgearsavoy] #629569
03/05/10 02:27 PM
03/05/10 02:27 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Thanks guys
Gus
So where did you guys run the 3 wires too? And must it be 3? I have a 2 wire plug that's why I'm asking?
Re: Toyota Alternator [Re: ademon] #629570
03/05/10 03:48 PM
03/05/10 03:48 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
its worth doing, i have electric F/P, small amp, with everything on wipers included it still puts out 14.2v at idle 850 rpm.
Re: Toyota Alternator [Re: CHRGR69] #629571
03/05/10 08:22 PM
03/05/10 08:22 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
Re: Toyota Alternator [Re: cruzin] #629572
03/05/10 09:02 PM
03/05/10 09:02 PM
Opelika, AL
JRs_Charger Offline
JRs_Charger  Offline
Opelika, AL
Just wanted to say I have the exact same setup from 440 source on my 440. The alternator is originally off an early 90's 4Runner I believe.
In my opinion its 100% worth the upgrade. Less weight over the nose of the car. Smaller more compact unit that frees up space underhood. Much more reliable part instead of the 40 Year old original units. Much steadier output at idle.
I love this conversion.
Re: Toyota Alternator [Re: JRs_Charger] #629573
03/06/10 08:36 AM
03/06/10 08:36 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I also did the headlight relay conversion. That is worth doing too. I HATE electrical issues. So I want to have a bulletproof electrical system as possible.
