Headlight switch wiring, 1971 Duster #629525
03/03/10 11:40 AM
03/03/10 11:40 AM
70duster340 Offline OP
I sure hope somebody here can help with this. Can anybody advise the wiring for the headlight switch? I need to know what each wire does. This is for a 1971 Duster wiring harness. I have a wiring diagram for a 1971 Valiant, but after staring at it for an hour or so, I am now confused. It would be extremely helpful if I knew each color, and what each wire does.
TIA!!!
Re: Headlight switch wiring, 1971 Duster [Re: 70duster340] #629526
03/03/10 12:03 PM
03/03/10 12:03 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
Try here: Mopar Wiring Diagrams 1966 to 1971
http://www.mymopar.com/index.php?pid=27
Common sense is a flower that does not grow in everybody's garden
Re: Headlight switch wiring, 1971 Duster [Re: Ron_M] #629527
03/03/10 12:12 PM
03/03/10 12:12 PM
I appreciate the quick response, Ron M, but I already have the wiring diagram, which I obtained from this website. What I really need is somebody to advise what each wire on the headlight switch plug does.
Re: Headlight switch wiring, 1971 Duster [Re: 70duster340] #629528
03/03/10 12:22 PM
03/03/10 12:22 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
That's not a simple circuit. You have outputs to the dash lights, dome light, head lights, running lights. These are also intermixed with the turn signal switch. A better question might be, what is your problem or what are you trying to accomplish?
Re: Headlight switch wiring, 1971 Duster [Re: Jim_Lusk] #629529
03/03/10 12:32 PM
03/03/10 12:32 PM
Thanks for replying, Jim. I am trying to wire in a Painless fuse block into the stock wiring harness. The stock fuse block was a bit suspect, and I thought the added protection for some previously unprotected circuits couldn't hurt, either. I really need to know what powers the switch. From what I can tell, it is a black/w white tracer, and a pink wire. There is also a tan wire that I am curious about.
Re: Headlight switch wiring, 1971 Duster [Re: 70duster340] #629530
03/03/10 05:58 PM
03/03/10 05:58 PM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
ok
black with tracer- + 12 volts in for headlights
pink- + 12 volts from fuse block for dash lights
yellow- ground for the dome light- note- headlight switch's metal body must be grounded to work.
tan- out to dash dimmer to fuse to orange wire to dash lights.
black- out to parking lights
Re: Headlight switch wiring, 1971 Duster [Re: 71_deputy] #629531
03/03/10 08:49 PM
03/03/10 08:49 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
You can also d/l the installations .pdf from Painless. The mopar kit colours are the same and it describes where they go.
Re: Headlight switch wiring, 1971 Duster [Re: GwaiiEagle] #629532
03/03/10 10:16 PM
03/03/10 10:16 PM
Thanks for the replies. That was exactly what I was needing!!!
Re: Headlight switch wiring, 1971 Duster [Re: 70duster340] #629533
03/04/10 12:22 AM
03/04/10 12:22 AM
Valencia, España
NachoRT74 Online content
NachoRT74  Online Content
Valencia, España
i though I gave you the guide here:
https://board.moparts.org/ubbthreads/showthreaded.php?Cat=0&Number=5843054&page=1&vc=1
sorry if you found some confusing specially about the tan becoming in orange and I described initially as orange
