Wiring panel to roll cage mount???
#629233
03/02/10 09:13 PM
03/02/10 09:13 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
Finishing the wiring and plumbing on my dads truck, and I do not have an NHRA rule book handy.
I was curious how they want you to fix the panel for ignition stuff & electrical acc? Can I put a bolt thru the cage or do tabs need to be welded on to fasten it too.
Justin
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
Re: Wiring panel to roll cage mount???
[Re: wldtm]
#629234
03/02/10 09:18 PM
03/02/10 09:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Justin
If you drill a hole in the tube you need to weld a tube into it.... tabs work fine
[Re: MR_P_BODY]
#629235
03/02/10 09:32 PM
03/02/10 09:32 PM
wldtm
Dayton, Ohio
Thank you sir. That is what I needed to know.
Justin
PM for details
[Re: wldtm]
#629236
03/02/10 10:02 PM
03/02/10 10:02 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
Slot the back panel of your control box and use hose clamps to fasten it to the cage. It worked for me . Chryco
Here`s a yet unfinished pic (not finish labeled )
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: chryco]
#629240
03/04/10 08:53 AM
03/04/10 08:53 AM
chryco
Winnipeg ,Mb. CA.
Here`s a pic or two of my electrical stuff . Hope it helps.
[Re: chryco]
#629242
03/04/10 08:59 AM
03/04/10 08:59 AM
chryco
Winnipeg ,Mb. CA.
The cable tray is made by a company named Panduit and is available from electrical / electronics suppliers in different sizes . Mine`s built from odds and ends I had from previous jobs. The fuse block is from a 78 Volare' . Chryco
