499 stroker combo HORSEPOWER? E.T.?
#628879
03/02/10 01:41 PM
03/02/10 01:41 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I just put together a 499 and wondering if anyone has any input on the comination of parts i used. This is my setup. 69 440 block arp main studs billet main caps, line bored, Bored .055 with torque plates, o decked block, eagle 4.150 crank, eagle h-beam rods with cap screws, srp flat top pistons, perfect circle file fit rings, mopar stage V1 heads raised port, full ported numbers around 310 in. @.600, they are milled down to 72cc combustion chambers,comp is at 12.5 cam in a doug herbert grind solid roller 268-275@50 620 lift is with 1.5 mopar performance alum. roller rockers,crower solid roller lifters, cam installed @-0, mopar m1 intake for the raised port heads the intake was also ported to match the heads,morosso 2" 4150-4500 adaptor and dominator 1050, and some crappy 1 3/4 dynomax headers. it has about 180 p.s.i. cold cranking compression. I have ran it for break in only. The oiling system is basically all stock with a high volume pump.I am putting it in a 67 charger leaf spring car with 727 coan 8" 5000 converter and 8 3/4 with 3.91 just wondering estimated horsepower and e.t. and if there is anything that just doesnt sound right.
Re: 499 stroker combo HORSEPOWER? E.T.?
[Re: dragram440]
#628881
03/02/10 01:47 PM
03/02/10 01:47 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Sounds like a really stout combo, and a nice quality parts list. Not sure how the dynomax headers made it on the list, but that would be my first to go - Get a good set of 2" headers. Should make 650-700hp and low to mid tens in the 1/4.
2 kids and a dog
[Re: Mr.Yuck]
#628882
03/02/10 01:48 PM
03/02/10 01:48 PM
dragram440
bigfork mn
I have the car mini tubbed with 28 x 14.50.quick time pros. I have m.w. 35 spline axles and a spool. no back brace. no trans brake
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#628883
03/02/10 01:48 PM
03/02/10 01:48 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
my old combo 493,10.5 to 1 comp, mp 590 cam, edel rpm heads, six pack intake i made ran 6.70 at 102 in the 1/8th around 101 mph at 3780 lbs
new combo with ez heads i ported and 630 roller cam, same six pack setup runs 6.30 at 109
2 inch headers and full 3" exhaust
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#628884
03/02/10 01:51 PM
03/02/10 01:51 PM
dragram440
bigfork mn
I have also read about drilling the oil pickup to the 1/2" and a couple other oil mods is this going to kill my new engine if I dont do these?
67' charger 499 RB
10.57 at 127
[Re: Mr.Yuck]
#628885
03/02/10 01:58 PM
03/02/10 01:58 PM
Posts: 130 Marcell, MN
68 Roadrunner
Marcell, MN
That's a lot of converter. I'll say mid-high 10's if it will hook. I'd probably back brace that 8.75. That's going to be a lot of torque.
The same converter worked good with this motor before it was stroked. I would think it would also work well now.
1968 Roadrunner 383 auto
.060 KB 400 domed pistons, Stealth heads, Torker intake, Holley 830, Lunati Voodoo cam 276/284, .513/.533, TCI 3500, 3.91 gears, all ARP fasteners,
[Re: dragram440]
#628887
03/02/10 05:38 PM
03/02/10 05:38 PM
68 Roadrunner
Marcell, MN
Sell me your headers and buy a new set! ![](/ubbthreads/images/graemlins/wink.gif)
