69 Brake Booster Repair........Midland-Ross #62881
05/24/08 05:40 PM
05/24/08 05:40 PM
Kansas 67208
8
8_Barrel Offline OP
super gas
8_Barrel  Offline OP
super gas
8
Kansas 67208
The input push rod (the one on the back-side that connects to the pedal) is retained in the plunger with a small plastic ring, naturally the plastic ring breaks when the push rod is removed.
Where to get that l'il plastic ring??? Or is there a "roadside fix" that works?
If you "Ain't Skeered" or have "No Fear", it's 'cause you ain't goin' FAST enough!!
Re: 69 Brake Booster Repair........Midland-Ross [Re: 8_Barrel] #62882
05/24/08 06:36 PM
05/24/08 06:36 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Re: 69 Brake Booster Repair........Midland-Ross [Re: earlybee] #62883
05/24/08 10:22 PM
05/24/08 10:22 PM
Kansas 67208
8
8_Barrel Offline OP
super gas
8_Barrel  Offline OP
super gas
8
Kansas 67208
http://www.magnumhp.com/catalog/product_info.php?cPath=22_26&products_id=270
Thanx for the link, however, a power brake input push rod uses a different retainer than a manual brake rod; why, I have no idea. The power unit uses a plastic ring that is about 1/4 the thickness of the manual unit rubber piece.
Pic is of the remnants of the plastic ring next to a single edge razor blade.
Or have you used the rubber piece on a power unit??
Re: 69 Brake Booster Repair........Midland-Ross [Re: 8_Barrel] #62884
05/24/08 10:32 PM
05/24/08 10:32 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Maybe find a rubber o-ring that size.
Re: 69 Brake Booster Repair........Midland-Ross [Re: earlybee] #62885
05/24/08 11:48 PM
05/24/08 11:48 PM
Kansas 67208
8
8_Barrel Offline OP
super gas
8_Barrel  Offline OP
super gas
8
Kansas 67208
The fsm says the ring is 'sposed to shear on disassembly, but there is no mention of replacing it on reassembly!!
I sliced a piece 1/4" fuel line thin and used that, all the while, my trusty l'il assortment box of o-rings sat discreetly on the shelf laughing their buns off!!!! So sharp I am!!!!
No fun replacing a power brake booster on a 4 speed car.
