Re: Need some help determining wheel backspacing.
[Re: 6PAX]
#628705
03/02/10 04:02 PM
03/02/10 04:02 PM
Posts: 2,255 IL
furious70
IL
not sure what style of rim you want, but the older centerlines are 8.5" wide and have ~5" backspacking, might be just what you need. They fit great with 30x10 slicks on my 69 Coronet, though that does you little good.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: GOLDMYN]
#628707
03/02/10 04:44 PM
03/02/10 04:44 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
this is why I prefer talking offset vs. backspace. offset is measured from the wheel centerline, backspace, from the inside edge of the wheel.
a typical 7" rim is 8" overall width, an 8" rim is 9" OAW (because the width is measured bead to bead)
so you found you need a 7" rim with 4 3/4" backspace. that would be 3/4" positive offset. so you'd need an 8" wheel with 3/4" positive offset. that would be an 8" rim with 5 1/4" backspace. if you get an 8" rim with the same backspace as the 7" rim, it'll only be 1/4" positive offset, and ALL of the extra 1" width will go to the outside.
