Master Cylinder Install - Quick Question #627921
03/01/10 03:13 PM
03/01/10 03:13 PM
440charger70 Offline OP
super street
super street
This is my first power brake job. I am installing a master cylinder to a power brake booster. On the back part that bolts to the booster, there is a small screw with a small triangular metal piece that looks to be holding the push rod inside of the master cylinder.
Just wanted to double check that this should be removed and if there are any other steps I should take prior to installation?
Thanks!
Re: Master Cylinder Install - Quick Question [Re: 440charger70] #627922
03/01/10 03:16 PM
03/01/10 03:16 PM
Andrewh Online content
Andrewh  Online Content
no, do not remove that.
THat prevents the piston from being pulled out completely from the mc.
You would pull that to rebuild it.
Re: Master Cylinder Install - Quick Question [Re: Andrewh] #627923
03/01/10 03:19 PM
03/01/10 03:19 PM
super street
super street
Well it's a good thing I asked! Anything else I should do or know before installing this?
Thanks.
1970 Dodge Charger 440 (NOM) 1971 Plymouth Duster 340 (#'s Correct) 2008 Jeep Wrangler Sahara. Nice Home for sale near Tampa FL http://ruskinonline.com/docs/WimaumaHouse.htm
Re: Master Cylinder Install - Quick Question [Re: 440charger70] #627924
03/01/10 03:58 PM
03/01/10 03:58 PM
most aftermarket booters have an adjustible rod at the end. you need to make sure it is adjusted properly.
Basically I look in the master cylinder. You can see the piston in the hole in the bottom.
I make sure that when I press it up to the booster, I don't see the piston move.
So you will have to adjust it to where you see the piston move, then screw it back in a little at a time, till you stop seeing the piston move when you press it flat. Then just a little more and lock it down.
Re: Master Cylinder Install - Quick Question [Re: Andrewh] #627925
03/01/10 05:58 PM
03/01/10 05:58 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Booster rod instructions
1MYTGTX
