Torque converter for 440? #627792
03/01/10 12:35 PM
03/01/10 12:35 PM
Westphalia, Meeeeeshigan
MIRADAMANia Online content OP
MIRADAMANia  Online Content OP
Any recommendations? Stall rpm, manufacturer? Lift: .488 intake .491 exh. duration@.050: 230 int. 236 exh. lobe sep.: 110, .030 over, 10:1, 3.55 gears, 27" tires, cast crank.
Re: Torque converter for 440? [Re: MIRADAMANia] #627793
03/01/10 12:39 PM
03/01/10 12:39 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
What's your cam, intake, exhaust and heads?
Re: Torque converter for 440? [Re: DaytonaTurbo] #627794
03/01/10 12:47 PM
03/01/10 12:47 PM
346 heads, lightly ported. Performer RPM. 2 1/2" dual exh.
Re: Torque converter for 440? [Re: MIRADAMANia] #627795
03/01/10 01:28 PM
03/01/10 01:28 PM
Manitoba, Canada
Manitoba, Canada
Headers or manifolds? That combo will probably like a 3000 stall.
Re: Torque converter for 440? [Re: MIRADAMANia] #627796
03/01/10 01:58 PM
03/01/10 01:58 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
2800-3k. 3.91's would really wake that up.
Coming soon!!!!
Re: Torque converter for 440? [Re: Mr.Yuck] #627797
03/02/10 01:16 PM
03/02/10 01:16 PM
With headers going in a 71 Charger R/T. I hear ya but I kinda have my mind set on the 3.55s right now.
Re: Torque converter for 440? [Re: MIRADAMANia] #627798
03/02/10 01:50 PM
03/02/10 01:50 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
My 71 Charger R/T has almost the same cam , TTI headers , portes 906 and a Holley street dom intake . with 355 rear and 275 tire I use a Stock converter (1800 stall 11.75)and I run high 12s at 110MPH . I really hate a slipping high stall converter on a heavy street car. I have also used a 10.75 oem converter (340/383 car) and it had a bit more low end power but seemed to slip alot more. I also tried a Dynamic 9 1/2 when I had a bigger cam (3500-3800 stall)but the car was slower by .1 and 6-7 mph. The higer stall also caused usless wheelspin on the street and the track (I use BFG drag radials for the track).The stock converter in the car now, even with a tall 275 tire will boil the tires from a stop all the way through 2nd gear and has stock drivability. That RB motor has so much low end that you dont need much stall.
Re: Torque converter for 440? [Re: THESHAKERPROJECT] #627799
03/02/10 03:10 PM
03/02/10 03:10 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I would call coan they were able to help me out. http://www.coanracing.com/
67' charger 499 RB 10.57 at 127
