Re: What would you do? Possible head issue......
[Re: BarryBum]
#627511
03/01/10 12:23 AM
03/01/10 12:23 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I would fix it, I would also check oil preasure with a real gauge first as the factory ones can be all over the place and they typically show lower than what it really is. You can pull the pan and throw bearings in those pretty easy, oil pump while your at it. But it is not too hard to pull the head and look around
