Re: What is your Compression ??
[Re: joshking440]
#627094
02/28/10 06:05 PM
02/28/10 06:05 PM
Posts: 3,336 Summit, NJ
whiplash
Summit, NJ
i"m running 8.98:1 with premium gas, and 10-12 lbs of intercoled boost
- 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
- 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
- NEW BEST ET - 12.40@110mph...
[Re: valiantboy]
#627097
03/06/10 05:03 PM
03/06/10 05:03 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
8 to 1,5lbs on pump gas,,,,,,,,for now
[Re: Defbob]
#627099
03/07/10 12:56 PM
03/07/10 12:56 PM
Posts: 833 MN
hemidup
MN
8.6:1 15psi with pump gas and w/m.
Jerry Williams.
[Re: Shaker223]
#627103
03/09/10 10:23 AM
03/09/10 10:23 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I'm learning about boost everyday and one thing i found out is not all boost is the same.
A centri blower does not need the compression cut like a roots/screw type charger due to the efficiency and RPM the boost comes in at.
I am going to be building a forged bottom end for my 32V Cobra and the recomendation is to stick with thr stock 9.85 compression or even go to 10:1. That is with an intercooled D1SC. Compression for use with a Kenne Bell PD blower would be much different.
Plenty of people are running 8-10# boost on stock 9.85 bottom ends. Thats hyper pistons and powdered metal rods.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Post deleted by Defbob
[Re: CJK440]
#627104
03/09/10 04:09 PM
03/09/10 04:09 PM
[Re: daithi2]
#627106
03/13/10 11:03 PM
03/13/10 11:03 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
Just measured up everything up tonight to double check....
70cc combustion chambers on Indy heads 27cc dishes in ross pistons .015 down hole .045 thick copper gaskets (just a tad for sealant thickness) with 4.06 bore 4.03 cylinder bore 4" stroke
comes out to 8.6 to 1.... going to be on E-85 and pushing lots of boost.
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
