sun tach #626947
02/28/10 01:34 PM
02/28/10 01:34 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
have older sun tach with 4 wire hookup,( with no wire attached ).the wire hook up is labelled 1- 12 volt key , 2-trigger , 3- light ,4-ground . is number 2 labelled trigger the coil wire ? thanks
Re: sun tach [Re: 426lloyd] #626948
02/28/10 01:36 PM
02/28/10 01:36 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Yep...negative side of the coil.
Re: sun tach [Re: OzHemi] #626949
02/28/10 01:51 PM
02/28/10 01:51 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
thankyou
