8.75 cap studs #626271
02/27/10 10:21 PM
02/27/10 10:21 PM
mo
ALKYW5DART Offline OP
mo
i am looking for arp studs for the 8.75 caps, i ve been told to get studs to beef up the rear end but i cant find them anywhere can you guys help thanks. yes i know i should do a dana but i own all this stuff so it will have to do for now
Re: 8.75 cap studs [Re: ALKYW5DART] #626272
02/27/10 10:44 PM
02/27/10 10:44 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I don't know if they are the same as a Dana but I used the Ford Motorsports kit from Jegs.I believe it was the one for the 8.8 rear.
Gus
64 Plymouth Savoy
Dana 60
Re: 8.75 cap studs [Re: fourgearsavoy] #626273
02/27/10 11:14 PM
02/27/10 11:14 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I don't think it's the studs are would be my first priority in strengthing an 8 3/4. MW caps and a brace for the back would do more to strengthen it IMO
Re: 8.75 cap studs [Re: WILD BILL] #626274
02/27/10 11:21 PM
02/27/10 11:21 PM
mo
mo
i understand what your saying i have a back brace nodular case 35 spool 1350 yoke i just want the extra piece of mind of arp studs in the caps
Re: 8.75 cap studs [Re: ALKYW5DART] #626275
02/27/10 11:28 PM
02/27/10 11:28 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I hear ya
Re: 8.75 cap studs [Re: ALKYW5DART] #626276
02/28/10 12:28 AM
02/28/10 12:28 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
What are the cap bolts diameters on the 8.75 rear if I may ask. mike
Re: 8.75 cap studs [Re: Sport440] #626277
02/28/10 01:18 AM
02/28/10 01:18 AM
1/2 by 20 if my memory serves me correctly
Re: 8.75 cap studs [Re: ALKYW5DART] #626278
02/28/10 05:36 AM
02/28/10 05:36 AM
Out of the State of Confusion
blue_stocker Offline
Try the Milodon 81274 studs, they should work quite well!...wb
Re: 8.75 cap studs [Re: ALKYW5DART] #626279
02/28/10 06:17 AM
02/28/10 06:17 AM
Queensland Australia
moparmacka Offline
moparmacka  Offline
I used left over studs from ARP 454 Chev 4 Bolt conversion stud kit. Can't quite remeber the exact lenght however, there are 2 studs in this kit that are not used in the 4 Bolt conversion for some reason, and they are the perfect length for 8.75 cap studs. Problem is you need two kits with the left over studs to obtain the 4 needed. I went to a local engine machine shop who had a bundle left over from converting 454's over the years and gave them to me as they would probably end up in the bin.
Macka
