Pennsylvania Emissions Inspection Custom Dodge Ram 4x4
#625658
02/27/10 11:34 AM
02/27/10 11:34 AM
Posts: 27 so.fla
OldRam
so.fla
Hello Moparts members, Is there anyone out there that lives in Pa. that knows the emmissions laws? I have a 1986 Dodge Ram 4x4 that had the 318 removed and replaced with 400 Big Block. Catalytic converter was removed and dual headers installed. Numerous calls to Pa. officials have not given me the answers I need to know about how this truck will be titled. We do not want a "R" title as this truck is not a salvage or Reconstruction per se, but a beautiful modified original. Any information will be helpful. Thanks Moparts.
Re: Pennsylvania Emissions Inspection Custom Dodge Ram 4x4
[Re: OldRam]
#625660
02/27/10 12:46 PM
02/27/10 12:46 PM
Posts: 222 morrisville, pa
skajm
morrisville, pa
where in pa are you moving? some counties on 96 and older is a visial(sp) and gas cap check. you will need the cats. the five phila counties will do a dyno test it will need cats. check out http://www.drivecleanpa.state.pa.ussee if this helps. why would your truck need an "R" title? joe
[Re: skajm]
#625663
02/27/10 03:44 PM
02/27/10 03:44 PM
Posts: 1,642 PA
70Duster
PA
1996 was the first year for OBDII so 1995 and older get the visual only inspection and 1996 and newer get plugged into the scanner to check code history.
All are emissions exempt if odomoter shows less than 5000 miles since last inspection.
