Re: Small block Crankshaft interchange
[Re: Kern Dog]
#625559
02/27/10 03:03 AM
02/27/10 03:03 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
yes ...318/273 is same bearing sizes and stroke...
will be needed to be balanced for the heavier 340 pistons...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 3ddart]
#625562
01/11/15 11:00 AM
01/11/15 11:00 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
Also check the converter/tranny input shaft hole size as they were smaller on the earlier l.a.s
yes , the 273 crank will have the small convertor register and most 318 cranks are CAST , not forged.
[Re: JohnRR]
#625563
01/11/15 02:35 PM
01/11/15 02:35 PM
Posts: 5,115 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
If you have an old 318 Poly crank they are steel. 273's are steel but as mentioned may have the wrong convertor register depending on year (I think 65 and back) Later 273's (66-68) seem to be a direct bolt in. A 318 has a steel crank in a factory truck motor. You would need to verify its an original. Only thing I have seen that makes them different is none of these were cross drilled for oiling like an original 340 was. I used what I thought was a 273 crack and rods in the Dart. I had several different steel cranks laying around. In the end I found out the one I had all the machine work done to was from a 65 truck 318 motor. It also had the incorrect crank register even though it was a stick motor. (Had a pilot bushing)When we did the balance work the new 340 pistons even being .060 over were lighter than the original 273 slugs. For my application using the lighter 273 rods it made for almost an even swap. In case your wondering I learned most of this the hard way. Nothing wrong with using the 273 cranks. Just be sure to verify everything is correct for your application BEFORE you assemble it. ![](/ubbthreads/images/graemlins/whistling.gif)
...FAFO...
[Re: skicker]
#625564
01/11/15 03:39 PM
01/11/15 03:39 PM
JohnRR
273 till at least 67 is small register crank and it wouldn't matter if the engine was bolted to a manual trans or an auto during the time frame.
[Re: JohnRR]
#625565
01/11/15 04:05 PM
01/11/15 04:05 PM
skicker
"The Champ"
"The Champ"
Western Md.
John..What is the year-split on small to large register for the 273-318? At 67 as you stated, doesn't make any sense. In different stuff I have taken apart I've never seen the small register crankshaft or convertor after 65.
...FAFO...
[Re: skicker]
#625566
01/12/15 03:28 PM
01/12/15 03:28 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
The 273-318 crank is heavier, the crank pins do not have lightening holes drilled into them.
The small register is for a TQ converter and will not matter on a manual trans unless you try to run the latemodel roller pilot bearing. My 68 273 had the big register, my 66 273 had the small one.
[Re: dogdays]
#625568
01/12/15 05:49 PM
01/12/15 05:49 PM
RapidRobert
Using the 340 crank you have in mind & with the right piston/rod etc choice it might be possible to get the bobweight(s) to what the crank is now with the 340 piston/rod (if you had one assy to weigh) but even so with Ma's poor balancing I would instead get a ten dollar HF gram scale & rig up a fixture to hold the rod horizontle such as your dial indicator stand & trim/deburr the rods till the rotating and reciprocating weight totals are the same on all (8) assys then give that single gram number (you add the rot/recip together (one is times 2 cuz there is (2) rod assys on a journal and the other is 1/2 of the total for (2) rod assys times 2. Google the formula it is simple) & give that total number to your balancer & it'll greatly reduce your bill as he ain't doing the deburring/trimming he just drills (hopefully) or adds Mallory to the crank plus you can smooth the rod shanks and trim the top/bottom balancing pads to get the assy as light as possible as your time is free (as opposed to his). you can trim the rod as much as you desire as long as you dont compromise its' strength and keep the (total assy) weights equal (individual components weights can vary no big deal) as the eng only sees the total assy wt that is on each journal. The pad on the small end manipulates the reciprocating (piston/rings/pin/locks (if used)/rod small end) weight and the big end pad manipulates the rotating (rod big end/bearings/rod bolts) weight. You grind on the rod to get em both where you want em (all (8) assys equal). EDIT Oops I saw that you have a 340 block & might use a 273/318/340 crank, same deal & if those cranks used a lighter rod/piston then you for sure want to lighten the rods you intend to use (Mallory ain't cheap) and get everything equal & have that gram number in hand for him
[Re: John_Kunkel]
#625570
01/12/15 06:12 PM
01/12/15 06:12 PM
RapidRobert
John I wanted to ask, when did the 904's go to the larger nub TC/diff input spline input shaft? & while you're here, the 60 deg approach angle for the .040" hole in the orifice in the leakdown tester, is that 60 the included angle or 60 on one side of the drill bit I will use? Thank you!
[Re: RapidRobert]
#625571
01/12/15 06:30 PM
01/12/15 06:30 PM
Posts: 26,032 Rio Linda, CA
John_Kunkel
Rio Linda, CA
904's went to the large pilot hub in '68.
Orifice angle is included angle. I'd use a countersink rather than a drill bit.
