Re: Alternative to Mopar .600 spring/retanr for Magnum head
[Re: Intense RT Dan]
#625188
02/26/10 10:34 PM
02/26/10 10:34 PM
Posts: 178 Tidewater, VA
TMCCuda
Tidewater, VA
I think there is a set of GM beehive v6 springs for sale in the Moparts small block section. Without looking up specs, Hughes Engines has springs and retainers that may be what you are looking for. Their 1110 springs are $94.40 and retainers are $62.00.
1970 Plymouth Barracuda
1994 Ram 1500 4x4 5.2L
2004 Ram 1500 4x4 5.7L Quad Cab
#625191
02/26/10 11:56 PM
02/26/10 11:56 PM
Posts: 1,371 Costa Mesa, CA
chache876
Costa Mesa, CA
Anyone have any pressure specs from testing these? It may have dropped (I suspect) but I had 280 open and 90 on the seat with .060 shims under stock Sealed Power replacement valvesprings. Will this give me more?
I'm interested but just want to see if I can get more info. Don't want to end up in the same boat.
from a thread in the archives...
"blueprint" specs were free length of 1.94", and spring rate of 365lb/in, so with the 1.6" IH I measured with the 3100 retainers, that would yield a seat pressure of 124lb, and a .5" lift pressure of 306lb."
https://board.moparts.org/ubbthreads/show...part=1&vc=1
#625195
03/01/10 12:33 PM
03/01/10 12:33 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
the GM 3100 spring "blueprint" info I got was I think from napa online. irreguardless, you can see the instron test on the link I got from testing a used junkyard one, ~330 lb/in rate, and ~90-100 lb seat pressure.
for my magnum heads, I ended up using hughes 1110 springs with 2.2L retainers. after a valve job, I had an IH of 1.63" with this combo, so I have ~.550" lift capacity and ~140-145lb closed pressure. runs fine with my cam, which is 259 adv, [Email]208@.050[/Email] lobe lift, [Email]127@.2[/Email] lobe lift, and .316" gross lobe lift. I'm running stock magnum rockers. it's a stock cam reground by bullet with their HR259/316 lobe
