Re: 69-383 Motor not making enough low end torque [Re: furious70] #624414
03/02/10 07:19 PM
03/02/10 07:19 PM
NW New Jersey
RSI700VIPER Offline
RSI700VIPER  Offline
NW New Jersey
You can advance the cam timing to get more low end power. Hopefully the cam was dialed in correctly. If not, that could be the source of your problem. I put a MP cam in a motor once that needed a 6 degree offset bushing to center it. I would never buy a MP cam again. Pure junk.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: 69-383 Motor not making enough low end torque [Re: RSI700VIPER] #624415
03/02/10 09:50 PM
03/02/10 09:50 PM
TX
68 Dart GTS Offline OP
TX
The cam degree was put in TDC, It's just a weekend cruiser not a race motor, i have some buddys with stroker 440's with alot more power and other Mopars with pretty much stock motors and they where installed TDC without advancing it and they run like a bat out of hell.
What am i missing on degreeing the cam for street use. Also any suggestions on who re-curves dist. in the Houston, TX. or surronding area's.
Thanks for all the imput, you guys have been alot
of help and carry the Mopar banner very well...
Re: 69-383 Motor not making enough low end torque [Re: 68 Dart GTS] #624416
03/03/10 07:31 AM
03/03/10 07:31 AM
Adelaide, SOUTH Australia
REDNICK Offline
REDNICK  Offline
I just installed a FBO dizzy advance limiter kit in my Coronet R/T with a solid 290 comp cammed 512/4sp/3.9. Local pump gas is 98 octane.(Australia)
In my application, I limited it to 14 deg total so I can run about 20 deg initial running to about 34 total.Vacuum advance not used in my case.
Also the advance springs were changed to delay the total to about 3k to compensate for the heavy car.
It went pretty good before, but it goes like a raped ape now...and revs VERY cleanly with no real chance of detonation with the low total advance number (my engine has high comp and alloy heads also-iron heads and lower comp would be better with up to 38(?) deg.)
Good kit for less than 40 bucks.Easy to install-good instructions
From "4secondsflat.com" guy.....
NEW From FBO
"Do it Yourself Advance Limiter Kit #J685
This kit contains our Exclusive and Patent Pending Advance Limiter Disc, RPM springs, complete step by step Full Instructions and our 47 Page Spiral bound"
"Tuning Guide"
Re: 69-383 Motor not making enough low end torque [Re: 68 Dart GTS] #624417
03/03/10 08:54 AM
03/03/10 08:54 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
where the cam is installed at (intake centerline) has the major impact on where the intake valve closes, which is what determines cylinder pressure. cyl pressure determines torque for the most part.
for an XE274, it's ground with a 110 degree LSA, but with 4 degrees of advance built in, so if it was degreed in to verify intake centerline, it should be at 106 degrees after top dead center (ATDC). that puts the intake close point 63 degrees after bottom dead center (ABDC). compare to a comp XE268, which has the intake close point at 60 degrees ABDC.
now assuming you used the KB flat tops at 0 deck, 906 (usually 90-92cc) heads, and a thin MP head gasket, that yields a true compression ratio of ~8.8:1. using one of the online dynamic compression ratio calculators, and plugging these assumptions in, the dynamic compression of this motor end up being ~7.1:1...by advancing the cam 4 degrees, the DCR jumps up to 7.3:1....advancing the cam will move the powerband down in the RPM range, giving a boost in low end and midrange, and a slight cost in the top end (how much time do you spend at 5500-6000 RPM anyway?)
in essence, it'll make your XE274 behave a little more like the smaller XE268.
2017 Grand Cherokee Overland
Re: 69-383 Motor not making enough low end torque [Re: patrick] #624418
03/03/10 11:19 AM
03/03/10 11:19 AM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
I don't think the cam is too big. Yes at the top end but not too big. Degree the cam. You never know really what the cam timing is unless you degree it. Advancing is a good plan. Change the intake to a dual plane. That will help. But understand that your buds have strokers and those motors have mounds of torque. You cant compete with that but you can make you combo the best it can be.
Re: 69-383 Motor not making enough low end torque [Re: BELVEDERE67] #624419
03/03/10 12:55 PM
03/03/10 12:55 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
When I have 3.23s in my street car(383) it runs the end of the track at 100mph.... in second gear.
This is not a 440, or a stroker. Its got the same size stroke as a torqueless 340.
It needs gears to do what you want it to do.
Re: 69-383 Motor not making enough low end torque [Re: RemCharger] #624420
03/03/10 01:01 PM
03/03/10 01:01 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
What rpm are you turning in 2nd gear at 100 mph.?
Re: 69-383 Motor not making enough low end torque [Re: ireland383] #624421
03/03/10 01:05 PM
03/03/10 01:05 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
6500.
Re: 69-383 Motor not making enough low end torque [Re: RemCharger] #624422
03/03/10 01:12 PM
03/03/10 01:12 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
6500 Awesome! To the op I had a 3.23 suregrip (cone) and couldn't break the tires free. Turned out to be a worn out suregrip, switched to 742 clutch type, 3.55's and was able to lay some nice slabs. Grant it this was before the rebuild of the motor. Still had the same stall 2400-2600. My cam is smaller Comps 275DEH 219/235 462/482.
Re: 69-383 Motor not making enough low end torque [Re: ireland383] #624423
03/03/10 07:42 PM
03/03/10 07:42 PM
the netherlands
3
383duster Offline
super street
383duster  Offline
super street
3
the netherlands
When you floor the pedal, does the engine goes to the ~3000 rpm as what the converter should be?
Recurved Distributors [Re: 68 Dart GTS] #624424
03/25/10 07:54 PM
03/25/10 07:54 PM
TX
TX
does anyone out there in Moparland know who would re-curve a MP distributor in the Houston, Tx area.
Thanks.
Re: Recurved Distributors [Re: 68 Dart GTS] #624425
03/25/10 09:41 PM
03/25/10 09:41 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
You. Just take it apart and put in the mr gasket lite springs. Then, if its not enough advance at idle, shorten the slots a bit.
Re: Recurved Distributors [Re: RemCharger] #624426
03/25/10 09:54 PM
03/25/10 09:54 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Summit sells the Mallory recurve kit. Pretty easy install. Comes with all the different springs and the little gauges for total. Pretty cheap too.
Re: Recurved Distributors [Re: Dougsmopars] #624427
03/25/10 09:58 PM
03/25/10 09:58 PM
Dougsmopars Offline
Dougsmopars  Offline
383 for a weekend crusier will do fine with 3:91 or even 4:10's. You can still go 70 on the highway. Like everything else you can't have the cake and eat it too. The car would be a lot of fun with 4:57's but forget the highway. Lose the torker it sucks for a street car. I'd advance the cam 4 degree's if it's just set dot to dot. And get your timing up.
Re: Recurved Distributors [Re: 68 Dart GTS] #624428
03/25/10 10:29 PM
03/25/10 10:29 PM
I'd find out how much initial your cam/eng wants then w that figure in hand & the chart weld up/shorten the slots to get 36-38 total (vac adv disconnected/hose plugged if you are using VA) and might have to dissassemble it (change slot length) several times to get it real close (spread the clip ends w your long thin needle nose pliers as much as you can in the tight confines in there then grab one end and whip it around to it's open side to open it up the rest of the way and up & out in 1 motion). Then play w the springs then hookup/play w the vac adv (if used)
Re: Recurved Distributors [Re: RapidRobert] #624429
03/26/10 01:59 AM
03/26/10 01:59 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Simple question
Have you checked the kick down linkage?
Re: 69-383 Motor not making enough low end torque [Re: 68 Dart GTS] #624430
04/18/10 01:18 AM
04/18/10 01:18 AM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Mopart guys, i'm having very low end torque problems. I have a 68 dart 383. It is pretty much stock but bored 30 over, schumacher headers, 383 torker mainifold with a new holley 770 avenger carb, new Comp. XE274 cam and lifters, stock heads ported and polished with HD springs, new pushrods, rebuilt 727 trans, 323 sure grip and 3000 hughes stall converter, stock elct. ignition with orange ECU box. Everything is pretty much new in the motor, compression test is good, vac.is good but it's totally a dog on the low end out of the hole. the motor runs great and it seems to make good power but it just seems like its not getting the power to the rear wheels at launch. I'm starting to think the new in the box stall converter which i bought from a friend may be clogged or have trash in it. Any suggestions are similar problems and fixes would greatly be appreciated. I have gotten pretty frustrated and don't want to just keep throwing more money at it and hope the problem gets solved. Compression is approx 9.5 - 1 to 10-1,vac.@ 14, intl., dist. @ 12. Thanks.
Go with the 4.10's. It is a trade off: noise/poor
mileage vs. great street/track performance. If you
are looking for a "true dual-purpose car", you will need an overdrive tranny or unit. Along with
the 4.10's, you have a choice. Either you can make the Torker work with a SMALLER carb (650cfm)
or go with the Eddy RPM manifold and your current
770 cfm carb. Optimize the power valve/jetting in either case.
Try to get your ignition at 35-38
deg. total at in by at least 2200rpms. Double check your compression ratio, since it is possible to have something closer to high 9's. You
did not indicate if you had ZERO DECK height or not. The
total timing may be affected by this factor.
Food for . That lightweight A body should be running, at the least, very low 12's. :twocents
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
