Re: Compression drop w/ replacement gasket on 318
[Re: 70Cuda383]
#624247
02/26/10 08:53 AM
02/26/10 08:53 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I am rebuilding a 1967 318 motor. It has the closed chamber 904 casting heads with small valves and runners. I bought a Comp 268 (218* at .050 .454 lift) cam kit. The cam wants 9:1 cr and 3.55 gears. I have read about the replacement head gaskets all being thicker and bigger bore than the original equipment 318 steel shim. I already also bought a full felpro 318/273 gasket set with the blue head gasket. I'm assuming it is a 318 gasket set because of port sizes not bore size?
Am I in for some machining? Heads/block decked? I don't want much more than a stock build if that matters. Super budget deal. Thanks
yup, the blue gasket is probably around .030 thick compressed.
to increase your compression, you WILL have to either
A) mill the decks B) mill the heads C) install different pistons with taller Comp. height D) Any combination of the above.
keep in mind that with milling the heads/decks, the intake side of heads might need touched so the intake still fits right, and you might need shorter pushrods.
the fel pro gasket that comes in those kits isn't .030 thick, it's .054" thick compressed. easiest thing to do is buy the $40 Mr. gasket .028" thick compressed gasket.
and it's actually the oil pan gasket that makes the 318/360 sets different. I can't remember if the rear main seal is the same or different between the motors, too...in all the complete gasket sets I've seen, they come with both sets of intake gaskets.
[Re: mod5v]
#624254
02/26/10 03:14 PM
02/26/10 03:14 PM
patrick
Grand Haven, MI
[Re: krw71ragtop]
#624258
02/26/10 09:07 PM
02/26/10 09:07 PM
Posts: 2,233 ILLINOIS
volaredon
ILLINOIS
The last batch of Felpro's I measured were .054"-.057" thick. I purchased the Mopar set #P4120094 from Mancini and are advertised at .024-.028" compressed.
I got these P-number thin ones, thru the local dealer when I put the EQ heads onto my LA 318 a year ago; I have a Magnum 318 in the machine shop as we speak I will be trying to get another set when that engine gets back here.
[Re: radar]
#624260
03/03/10 11:08 AM
03/03/10 11:08 AM
Posts: 1,822 Colorado
denfireguy
Colorado
I just ordered set off of Amazon as well. It appears that this part is discontinued. If you want a thin gasket, might be best to order one now. Somehow I wonder if there ever will be any made again.
Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: radar]
#2236833
01/18/17 05:30 PM
01/18/17 05:30 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
Didn't FelPro used to make a steel shim factory style head gaskets? Whether this is a good idea or not...but my dad would spray paint those gaskets with silver paint....my cousin sprays them with copper coat to help them seal.
Moparlee
[Re: Baxter61]
#2237279
01/19/17 02:57 PM
01/19/17 02:57 PM
denfireguy
Colorado
First, this is a 7 year old thread that has been resurrected from the dead. And things have changed a bit. The Mr Gasket 1121G (.028 compresses) that was disappearing then is back in stock at Summit and many other vendors. Guess it was just a seasonal shortfall. Craig
[Re: radar]
#2237320
01/19/17 04:42 PM
01/19/17 04:42 PM
Posts: 1,232 Chicago, IL
PLUM_72
Chicago, IL
Cometic has a 4.04 bore gasket for the small block with a 0.027" compressed thickness. The trouble there is they are about $80 each.
1972 Dodge Challenger
