Re: Turbo Big Block Header Pics
[Re: Defbob]
#623306
02/25/10 09:45 AM
02/25/10 09:45 AM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
[Re: joshking440]
#623307
02/25/10 09:47 AM
02/25/10 09:47 AM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
[Re: joshking440]
#623308
02/25/10 09:49 AM
02/25/10 09:49 AM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
[Re: joshking440]
#623311
02/25/10 02:34 PM
02/25/10 02:34 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Looks nice how is the exhaust routed for the turbo? Will it exit out normally under the car?
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: joshking440]
#623314
02/25/10 04:45 PM
02/25/10 04:45 PM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
there is a little more room then what appears in the pictures, but not a lot. I would say I have 3" or so from the cap to the tube. We are actually looking at making a heat shield for that crossover tube, just in case though
Ever though about just using header wrap? My down pipe is about 1/2" away from my cap and the wrap works well. Really keeps the heat down.
[Re: HealthServices]
#623315
02/25/10 06:04 PM
02/25/10 06:04 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
Well that isn’t going to work for a street car.
Do you mean because it looks like it hangs low?
Post deleted by Defbob
[Re: moparmattkos]
#623320
02/25/10 06:54 PM
02/25/10 06:54 PM
#623321
02/25/10 08:13 PM
02/25/10 08:13 PM
Posts: 7,759 So Cal
HealthServices
So Cal
With what I read the size, length, tuning of the exhaust is not as important before the turbo, as the restriction is in the turbo itself and the exhaust after it. These are plenty 700+ hp turbo motors out there with just logs.
Allen
#623322
02/25/10 08:49 PM
02/25/10 08:49 PM
