Re: 98 Plymouth Grand Voyager Power steering pump replace
[Re: MNobody]
#623297
02/25/10 10:46 AM
02/25/10 10:46 AM
Posts: 1,822 Colorado
denfireguy
Colorado
I took the pulley off while it was still on the engine then took the pump off the engine. Dropped the exhaust system from the flange and removed it. Snaked it out the back underneath. This was on a 3.3L engine. Not sure it is any easier than taking off the axle. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: MNobody]
#623298
02/25/10 10:53 AM
02/25/10 10:53 AM
Posts: 21,450 It's a dry heat
gtx6970
It's a dry heat
I have to replace the pump i pretty sure the shaft seal is bad and it sound's like a big project, anyone have any tip's or trick's they can share? Thanks.
what engine and with or without rear A/C ?
