duster question #622049
02/23/10 06:58 PM
02/23/10 06:58 PM
wisconsin
jp66charger Offline OP
wisconsin
Just bought a Duster from a friend of mine. Can't get it home because 1)it's buried in his shop and 2) our roads are white with salt. Car is all stock with original 8 3/4 small bolt pattern and stock spring location. Thinking I will leave 14" rally's on the front and order 15's for the rear from wheel vintiques. Since the car is not here I can't measure easily. Can anyone tell me what's the largest radial tire I can run on an all stock setup and what back spacing rim to order? Thanks, JP
Re: duster question [Re: jp66charger] #622050
02/23/10 07:45 PM
02/23/10 07:45 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
From the tech archives. A graet place to look when you need info. http://www.moparts.org/Tech/Archive/wheels/4.html
