Re: Rocker arm help
[Re: moparderek]
#621792
02/23/10 03:06 PM
02/23/10 03:06 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Crane is back in business with a full product line.
Re: Rocker arm help
[Re: AndyF]
#621795
02/23/10 04:24 PM
02/23/10 04:24 PM
Posts: 19 Montreal,QC Can/Alburg,VT USA
moparderek
I'm just not big on the aluminum stuff. I want it to last. I want to know what you guys have had good experiences with. I'm runing a mild solid and I just need something simple and durable. And I checked the crane cams site, they were bought out by s&s motorcycles and are only producing bike parts and ignition components.
Re: Rocker arm help
[Re: moparderek]
#621796
02/23/10 04:43 PM
02/23/10 04:43 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Nothing wrong with aluminum rockers. All high end rockers are aluminum, and take the abuse of well over a thousand lbs or pressure fully open. Saying this not all rockers are made equal. A street and strip 440 however doesn't need a set of $1000 rockers IMO. Try to pick a part based on your package that will do they job cost the less, without a compromise in durability is my philosophy. But try to think about future upgrades. It doesnt save you money when two years from now you decide to run a stout flat tappet, or even a solid roller. I set of the Ductile rockers like crane and isky is fine for even a moderate sized flat tappet. Make sure you run these bushed rockers with a chrome hard rocker shaft..Id look at mancini racing for those. For a entry level aluminum rocker I would look at the Hughes rockers, or a set of the Indy (Dove) Rockers. Those Dove rockers are pretty well priced and some have luck running a solid roller with them. They are easy to find as take off's, when people upgrade. They are in the Race parts for sale section about every month. and usually in the $250-$400 range depending on shape and extra's. Then the Higher end stuff..usually in the $1k and up range.. is the Harland Sharp's, these are a nice rocker arm will fit the bill for about any thing you want to run. Jesel and T&D Machine.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: Rocker arm help
[Re: AndyF]
#621798
02/23/10 06:01 PM
02/23/10 06:01 PM
Chris2581
Jacksonville, FL
Crane has been posting an ad in National Dragster stating that they are a contengency sponsor with full parts line.
Re: Rocker arm help
[Re: 493_DART]
#621800
02/24/10 01:17 AM
02/24/10 01:17 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I'll get ripped for this, but what the hey..... A few years ago I bought a set of ProComp Electronics Steel Rockers. Roller tips, they came with hardened shafts, rocker bodies have bronze bushings, adjuster studs have oiling provisions. They've performed well for me, and were downright cheap. For a high rate roller cam, I'd spend more, but for a street / strip effort with 350 lb's of open pressure or less, I'd buy another set.
Re: Rocker arm help
[Re: StealthWedge67]
#621801
02/24/10 07:30 AM
02/24/10 07:30 AM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
Ya, your right, I can't resist. You posted this the other day - right?
"One of my rocker studs snapped while snugging down the jamb nut. These Are Pro-Comp rockers with cup-end adjuster studs for ball end pushrods. I'm thinking that if one snapped, I should replace them all. Went to Summit.... Can't find much. Who would have the best deal on these? Also, is there a strength or durability advantage to a ball-end stud / cupped pushrod setup?"
FWIW, I didn't break because of the oil hole.
