Page 1 of 3 1 2 3
B&M Supercharger #621721
02/23/10 01:39 PM
02/23/10 01:39 PM
NJ
moparply Offline OP
moparply  Offline OP
NJ
Can this low profile B&M Supercharger be used on a Mopar engine, can you purchase the correct adapter seperately.
It's the model 144 Powercharger for a small block Chevy.
Re: B&M Supercharger [Re: moparply] #621722
02/23/10 03:18 PM
02/23/10 03:18 PM
Chicagoland
chargerron69 Offline
Chicagoland
it could, but you need the intake for the engine. and they are very hard to find. the 144 is a little small unless its going on a 318. i have a 174 with both big block intakes if your looking. been trying to sell and havent really had any success. PM if your interested, or need more info.
Ron
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
Re: B&M Supercharger [Re: chargerron69] #621723
02/24/10 02:37 AM
02/24/10 02:37 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Ron does have a sweet setup for sale if you're looking. I messaged him about it back in september and he sent some good looking pics. But I couldn't scrape up the cash at the time.
Re: B&M Supercharger [Re: DaytonaTurbo] #621724
02/24/10 12:35 PM
02/24/10 12:35 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Dick Landy Ind used to sell that blower kit. Looks like he used modified Offenhauser dual quad intakes for the manifold.
Keep old mopars alive.
Re: B&M Supercharger [Re: 2boltmain] #621725
02/24/10 01:30 PM
02/24/10 01:30 PM
Chicagoland
Chicagoland
thats exactly what they used. had to find one for a low deck so i could make it work on the 383. and thanks for the plug daytona!
Re: B&M Supercharger [Re: chargerron69] #621726
02/24/10 06:16 PM
02/24/10 06:16 PM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
Ron,
Any chance in seeing some more pictures of the 147 w/ the big block intake?
Re: B&M Supercharger [Re: Pat_Whalen] #621727
02/24/10 08:04 PM
02/24/10 08:04 PM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
I used to have a 144 on a slant six it was kind of fun till the rod broke I could dig up some pictures if you want
Re: B&M Supercharger [Re: NoFrills] #621728
02/25/10 01:24 AM
02/25/10 01:24 AM
Chicagoland
Chicagoland
first few are on the 383 in the car blue ones are mock up on 440
Re: B&M Supercharger [Re: chargerron69] #621729
02/25/10 11:21 AM
02/25/10 11:21 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Is it mandatory to mill out the 2x4 carb mount pads and weld in the new pad on an Offy or could one have a bolt on adapter plate made to bolt the little blower to an untouched intake? The small block intakes are plentifull used and as far as I know still avail new. I bought this one from summit in 2003. The date cast in shows it was poured in 2002.
Re: B&M Supercharger [Re: 2boltmain] #621730
02/25/10 02:02 PM
02/25/10 02:02 PM
Chicagoland
Chicagoland
i had mine copied from the 440 intake cut out the entire center an welded in a 5/8 aluminum piece in and it has to be made on the same plane as the crank c/l.
this is the landy one.
they wanted $1000 to make one
Re: B&M Supercharger [Re: chargerron69] #621731
12/02/10 08:44 PM
12/02/10 08:44 PM
pa
amx440 Offline
amx440  Offline
pa
you still have that supercharger setup i have a 440 in my amx and it looks like it might fit under the hood. I have a rpm high rise dual plane with a 1 inch spacer and i still have room
Re: B&M Supercharger [Re: amx440] #621732
12/11/10 12:35 AM
12/11/10 12:35 AM
wisconSIN
Blown61 Offline
Blown61  Offline
wisconSIN
How much boost where you getting out of that setup?
Re: B&M Supercharger [Re: Blown61] #621733
12/16/10 11:03 AM
12/16/10 11:03 AM
Sterling Heights, Michigan 483...
daniel_depetro Offline
Or you could simply run a plate on a intake manifold with the carburetor flange milled flat.
That's what we've done for years until we finally found some great deals on real supercharger intakes.
In fact our current 1972 Dodge Dart is set-up this way.
Holley Street Master single plane intake with carburetor flange milled flat and a 5/8" flat aluminum plate to mate the blower to the intake.
This supercharger was part of a complete small block Chevrolet kit dad got a smoking deal on (~$650.00). Shortly afterwards he picked up a brand new complete polished small block Chevy kit for $1,000.00.
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
Re: B&M Supercharger [Re: moparply] #621734
12/16/10 11:39 AM
12/16/10 11:39 AM
Ont, Canada
moparo Offline
moparo  Offline
Ont, Canada
OHHHHHHHH YAAAAAAAAAAAAAAAAA it sure can.
performancecarrestorations.com
Re: B&M Supercharger [Re: moparo] #621735
12/16/10 01:45 PM
12/16/10 01:45 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
hmm something i have noticed in this thread is a distinct lack of vissible blow of valves it may be mee just being blind
,some say they are very important and some says they are not needed
Re: B&M Supercharger [Re: 1Fast340] #621736
12/16/10 02:04 PM
12/16/10 02:04 PM
The complete 142-177 supercharger systems (Chevrolet/Mopar) I have purchased so far never had a pressure relief of any type.
Probably because of the low boost output of these small superchargers?!?
I have a few small block set-ups and a Dick Landy Industries 174 supercharger set-up for a 440.
Here is my DLi intake manifold:
This is an NOS (in box) B&M small block Mopar intake manifold we paid $350.00 for:
Re: B&M Supercharger [Re: daniel_depetro] #621737
12/16/10 03:33 PM
12/16/10 03:33 PM
Ont, Canada
moparo Offline
moparo  Offline
Ont, Canada
I have a dick landy set-up in my AAR which the original owner had installed. Set-up work great.It is the next mopar action april 2011
Re: B&M Supercharger [Re: 1Fast340] #621738
12/17/10 10:34 AM
12/17/10 10:34 AM
I just read this on the Holleys Tech section on their website:
Direct link to the Holley FAQ/Q&A
QUESTION: My supercharger uses a serpentine style drive belt. Do I need a “pop” off plate if it backfires?
ANSWER: No.
The serpentine style drives do not require a “pop” off plate. If the engine backfires it will slip the belt on the pulleys. If the blower is running a Gilmer (tooth) style drive setup then it does require a “pop” off plate. If a backfire occurs on a Gilmer drive setup the belt will NOT slip and it may lift the blower off of the intake manifold.
I can't wait to see that article.
Refreshing to see some of these high performance cars still being used as high performance machines!
Wait...before I get my entire foot in my mouth please tell me it isn't just another yuppie show pony/trailer queen.
Re: B&M Supercharger [Re: daniel_depetro] #621739
12/19/10 01:59 PM
12/19/10 01:59 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I remember looking at a B&M pamphlet in the late 80s. They listed for the SBC their blower kit to mount directly on a carburetor intake manifold. The exact words they used were that on a street driven car the lesser power (Compared to a dedicated blower intake manifold) would not be noticed.
Re: B&M Supercharger [Re: 2boltmain] #621740
12/19/10 02:28 PM
12/19/10 02:28 PM
Manitoba, Canada
Manitoba, Canada
I thought those blowers that mounted directly to the carb pad were typically lower in output, as in topping out in the 400-450hp zone...?
Page 1 of 3 1 2 3
