Distributor identification #621308
02/22/10 10:35 PM
02/22/10 10:35 PM
Chicago
curbman68 Offline OP
Chicago
I bought a Prestolite distributor unseen from a guy who restored this car and had it left over. He said it was a Hemi Cuda and the owner wanted electronic ignition instead of the dual points, so the restoration guy kept the distributor. The only problem is the tag has been broken off. The distributor is in real nice shape, any way to tell what it's from without the tag?
Re: Distributor identification [Re: curbman68] #621309
02/22/10 10:37 PM
02/22/10 10:37 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
No, with no tag, there's no way for a positive ID. It's just another dual point, but those aren't exactly cheap these days even without a tag in that condition. The vacuum diaphram does look correct for 1970. Does the cap have "Made in the USA" molded into the top?
Re: Distributor identification [Re: ScottSmith_Harms] #621310
02/22/10 10:48 PM
02/22/10 10:48 PM
Chicago
Chicago
The cap does have the "Made in USA", it's pretty nice, doesn't look too worn, but a little chewed up on the top of one of the towers. It would be under the plug wire boot though. It needs some cleaning though.
Re: Distributor identification [Re: curbman68] #621311
02/22/10 10:52 PM
02/22/10 10:52 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That's a correct cap. All in all it's probably a Hemi distributor, looks the part but it could just as easily be a 440 unit, as I said, no tag, no pos id. Reproduction tags are available but be forwarned, there isn't one out there that will pass as the real thing, they all have small flaws that make them recognizable as such.
Re: Distributor identification [Re: curbman68] #621312
02/22/10 10:58 PM
02/22/10 10:58 PM
MD
floyd Offline
floyd  Offline
MD
Check with these guys, mabe they can offer some advice: http://paramountd.com/
Re: Distributor identification [Re: curbman68] #621313
02/22/10 11:03 PM
02/22/10 11:03 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Look at the arm on the vacuum advance and see what the stamped number is.
Also check for numbers stamped on the centrifugal advance shaft.
Re: Distributor identification [Re: floyd] #621314
02/22/10 11:04 PM
02/22/10 11:04 PM
Chicago
Chicago
Thanks for the info. I originally wanted it for the shaft to repair another distributor I have, but I think it's too nice to strip for parts.
I checked out Paramounts site, I would love to have one of those Sun distributor machines they have. Probably wouldn't get much use, but would look cool in the garage. Kind of an expensive piece of garage art though.
Re: Distributor identification [Re: curbman68] #621315
02/22/10 11:28 PM
02/22/10 11:28 PM
Snoopy Offline
Snoopy  Offline
At least it is a 70-71 BB distributor.
If you decide to remove the shaft, look on the bottom plate for a stamped number. There will also be a letter stamped on the top plate, but I don't know if it is relevant.
Re: Distributor identification [Re: Snoopy] #621316
02/23/10 12:21 AM
02/23/10 12:21 AM
Chicago
Chicago
There is an "8" stamped on the vacuum advance arm. Do you know which distributors got which can?
Re: Distributor identification [Re: curbman68] #621317
02/23/10 12:50 AM
02/23/10 12:50 AM
Snoopy Offline
Snoopy  Offline
8 - 70-71 Hemi
11 - 70 440-6
Re: Distributor identification [Re: Snoopy] #621318
02/23/10 07:59 AM
02/23/10 07:59 AM
MD
floyd Offline
floyd  Offline
MD
Snoopy - How about 340-6?
Re: Distributor identification [Re: floyd] #621319
02/23/10 09:16 AM
02/23/10 09:16 AM
Snoopy Offline
Snoopy  Offline
I don't have one of those distributors, so I can't be of much help. Maybe one of the AAR or T/A guys can answer your question.
Re: Distributor identification [Re: Snoopy] #621320
03/25/10 11:29 PM
03/25/10 11:29 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Funny enough, I also have a dual point distributor missing the tag that I bought as a '70 440 6bbl part. It wasn't as nice as the one above, so I completely disassembled it, cleaned it up, glassbeaded and painted the housing, etc. I just checked the vacuum advance arm and it is stamped 11 and the wire lead is the long 6bbl type, so I guess it is a real V-code distributor. Snoopy, what will be stamped under the advance mechanism if it is a 6bbl distributor? I already assembled mine, but I will pull it back apart to find out
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: Distributor identification [Re: 70440+6bbl] #621321
03/26/10 12:02 AM
03/26/10 12:02 AM
Snoopy Offline
Snoopy  Offline
3420919 70 440-6 vacuum Advance
Re: Distributor identification [Re: 70440+6bbl] #621322
03/26/10 12:22 AM
03/26/10 12:22 AM
Snoopy Offline
Snoopy  Offline
I don't know, I only have a manual 70 Hemi shaft on hand for reference.
Re: Distributor identification [Re: Snoopy] #621323
03/26/10 08:20 AM
03/26/10 08:20 AM
Chicago
Chicago
Other than the number on the tag, is there a difference between a distributor from an auto car as opposed to a manual car?
Re: Distributor identification [Re: curbman68] #621324
03/26/10 02:48 PM
03/26/10 02:48 PM
Snoopy Offline
Snoopy  Offline
Hemi Distributors.
Prior to 70, auto and manual used the same distributor. In 70 & 71 a different distributor was used for manual and auto transmission.
The difference is shown in the chart below.
From the 70-71 Factory Parts Book.
2875987 - 70 Hemi Manual trans.
2875989 - 70 Hemi Auto trans.
Re: Distributor identification [Re: Snoopy] #621325
03/26/10 09:01 PM
03/26/10 09:01 PM
Chicago
Chicago
Thanks for posting the chart, that is interesting. It looks like the only way to tell the difference between an auto and manual trans distributor would be to take it apart and see what is stamped on the plate attached to the shaft.
Re: Distributor identification [Re: curbman68] #621326
03/27/10 05:05 PM
03/27/10 05:05 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The only problem with that being is the numbers are Prestolite numbers not Chrysler.
Re: Distributor identification [Re: 62maxwgn] #621327
03/28/10 02:40 AM
03/28/10 02:40 AM
Snoopy Offline
Snoopy  Offline
Maybe this will explain the differences?
From the 70 FSM.
