Trans Pan Gasket Question #62106
05/23/08 12:47 PM
05/23/08 12:47 PM
wisconsin
kmfdm Offline OP
kmfdm  Offline OP
wisconsin
Does anyone here know the part number for the steel shimmed reusable trans pan gasket for a 727?
74 Dart Sport
Re: Trans Pan Gasket Question [Re: kmfdm] #62107
05/23/08 01:01 PM
05/23/08 01:01 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
last part number Ihave is 2464324ac
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Trans Pan Gasket Question [Re: kmfdm] #62108
05/23/08 01:05 PM
05/23/08 01:05 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
MOPAR part #2464324AC,should be around $15...hope this helps
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: Trans Pan Gasket Question [Re: racerAL] #62109
05/23/08 01:11 PM
05/23/08 01:11 PM
wisconsin
kmfdm Offline OP
kmfdm  Offline OP
wisconsin
Thanks guys! Now to just find one in stock!
74 Dart Sport
Re: Trans Pan Gasket Question [Re: kmfdm] #62110
05/23/08 01:46 PM
05/23/08 01:46 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
For future reference (and so folks can find it again later) the part number is in the archives.
http://www.moparts.org/Tech/Archive/auto/25.html
Rich H.
Esse Quam Videri
Re: Trans Pan Gasket Question [Re: kmfdm] #62111
05/23/08 02:03 PM
05/23/08 02:03 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
not sure which part of Wi.ur in but i ran a quick locator for Wi. and found a few differt dealers that stock that gasket.Palmen motors in Kenosha & in Racine,Russ Darrow Chry. Jeep in Mlw.,Dodge City of Mlw.also Ewald jeep dodge in Franklin Wi.Miller motor sales in Burlington.....good luck
446 cid on E-85
best 60ft. 1.419
Re: Trans Pan Gasket Question [Re: racerAL] #62112
10/16/11 12:12 AM
10/16/11 12:12 AM
Maryland
reno340 Offline
reno340  Offline
Maryland
About the 2464324AC gasket for the 727,do they still make this? Who is a good online source if I need to get one?
Re: Trans Pan Gasket Question [Re: reno340] #62113
10/16/11 02:53 AM
10/16/11 02:53 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
When I worked for a Dodge dealer I had a few around my garage. Most are gone and they seem to work best on an aluminum pan with a nice flat surface. Ron
