How to build torque
#620965
02/22/10 02:58 PM
02/22/10 02:58 PM
Posts: 583 San Antonio, TX
CurYellowBird
San Antonio, TX
I'm doing a relatively stock HP 383 build and am either going to go with a stock replacement cam or the XE262H to keep good torque numbers.
What are some other ways of building torque? Increase in timing? Gears? etc.
I'll be driving a 71' Roadrunner, which is at or little over 4000lb. with the options it has and what not. So torque is important to move this tank lol.
Project War Bird:
1971 Plymouth Roadrunner
383 4 speed with air conditioning
GY3 Curious yellow
All original
Re: How to build torque
[Re: DaytonaTurbo]
#620969
02/22/10 04:56 PM
02/22/10 04:56 PM
Posts: 15,487 Florida
scratchnfotraction
the whiplash from hughes has early intake closeing to build cyl pressure so it wont kill off any torque in a low CR engine thats gonna be my way of making some torque
[Re: scratchnfotraction]
#620970
02/22/10 06:33 PM
02/22/10 06:33 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
well, if it's torque you want, then you'll be looking to maximize power at lower RPM, vs spinning it to 7500rpm for max power.
you'll want long intake and exhaust runners, smaller (stock sized) valves to keep air velocity up at the lower RPMs, and a smaller carb for the same reason.
the long runners like on a cross ram intake with the carbs out over the fenders, will make peak power at a much lower RPM due to the time it takes for the pressure waves to bounce back and forth inside. short runner intakes will make peak power at higher RPMs. same goes for exhaust, longer primaries on the headers makes for lower RPM peak power.
but, a cross ram or tunnel ram may be a bit extreme. an intake like the perf. RPM is a good compromise and will make good low end torque. any long tube header with a smaller primary size will also suffice.
**Photobucket sucks**
[Re: Stanton]
#620972
02/22/10 07:09 PM
02/22/10 07:09 PM
CurYellowBird
San Antonio, TX
I'll be keeping the HP manifolds and probably the HP intake. I've heard good things about the HP intake flowing just as good as a performer, its just heavy as hell.
For compression, I think the 71' engines were 8.5:1 so I'm gonna definately get that up to par. I have a carter AFB 750cfm carb that the previous owner put on. I don't have the original one. I messed with camquest and the original cam specs or the XE262H is giving the best torque numbers along with good HP numbers.
What about exhaust tube sizing? I know 3 inch is far to large for a torque oriented build. I have the original exhaust that is quite clean and can be reused. I think it is 2 1/4 size tubing, but of course does not have a h-pipe.
Project War Bird:
GY3 Curious yellow
All original
[Re: SomeCarGuy]
#620974
02/22/10 07:54 PM
02/22/10 07:54 PM
stroker kit
this.
otherwise your gonna need alotta rpm to get some nice torque #'s.
#620975
02/22/10 08:00 PM
02/22/10 08:00 PM
CurYellowBird
San Antonio, TX
A lot of rpm to make torque? Isn't it the other way around where a lot of rpm makes horsepower?
I'm not stroking the numbers engine. I'm just looking at doing basic improvements to improve the engines performance and make up for some lost hp/lb. numbers in 71'.
Project War Bird:
GY3 Curious yellow
All original
[Re: CurYellowBird]
#620976
02/22/10 08:19 PM
02/22/10 08:19 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
Just stick with your plan. XE262H cam.
Work on the timing and carb setup. Tune, tune, tune!
Run that 2 1/4 inch exhaust with some good flowing mufflers. Add an H or X pipe if you can.
The Edelbrock Performer RPM intake will really help over a stock intake, but it's almost 2" taller than the stock intake.
If you need to do any head work, have them blended, milled 0.030 or 0.040 and have a 3 angle valve job, and use the steal shim head gaskets.
All this will give you a good running cruiser that'll run stronger than a stock 1970 Road Runner 383.
Your running a 4 speed, right?
[Re: Junky]
#620978
02/22/10 08:48 PM
02/22/10 08:48 PM
CurYellowBird
San Antonio, TX
Yep Junky, I am running a 4 speed
Project War Bird:
GY3 Curious yellow
All original
[Re: Sport440]
#620981
02/23/10 12:59 AM
02/23/10 12:59 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
I like the mild cam, and timing curve idea, but I'm going to respectfully disagree on the rpm intake. Go with the regular performer instead. I'm pretty sure the specs on the rpm specify that it is meant for lighter stuff, and higher stalls. I have a 400 I built for moving my 5000 plus van around, and it seems to work best with a stock iron intake. Don't get me wrong here, I run an rpm in my 330, but it's a little wilder. I think a regular performer, and tune it with 4 hole spacers to get a little more torque out of it, would be best for this 383.
[Re: DaytonaTurbo]
#620983
02/23/10 08:53 AM
02/23/10 08:53 AM
Posts: 283 N.E. England
Roppa440
super street
super street
N.E. England
Where does torque come from?
I will tell you. It comes from the energy released from the fuel you burn. The more fuel you burn the more torque you have.
Simple as.
So larger capacity, forced induction, NOS, etc will all give you big torque.
Where you make that torque (at what rpm) is what decides how much HP you have.
All torque at low rpm makes for a poor performance engine. Like a steam engine or truck. You are better making torque at high rpms if you want a good top speed. That is where the cam (valve timing) comes in.
Best way to improve torque on a 383 is to stroke it or throw it out and fit a 440.
2002 Chevrolet Corvette 5.7 LS1
2011 Alpha Romeo Giulietta Veloce 1.6 JTD
Because running a Mopar in the UK is getting TOO expensive!!
[Re: Roppa440]
#620984
02/23/10 10:40 AM
02/23/10 10:40 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
headers are the cheapest way to make torque...in just about every BB dyno shootout Dulcich has done in Mopar Muscle, long tube headers usually pick up ~20 lb-ft over stock exhaust manifolds.
for your 383, I'd also run KB flat tops at 0 deck with closed chambered heads.
