10 Inch Rear wheel on stock 71Challenger? #620630
02/22/10 12:28 AM
02/22/10 12:28 AM
Port Alberni, British Columbia
MoparDonny Offline OP
Can it fit without a Dr.Diff offset hanger kit or am I best to stay with a 15x8 w/4.5 Backspace. I was thinking 15x10 with 5.5 Backspace. I'm probably in the 475 Horsepower range with the new motor so I don't need a huge tire anyway and it's mostly street driven.
Thanks guys.
Don.
Re: 10 Inch Rear wheel on stock 71Challenger? [Re: MoparDonny] #620631
02/22/10 12:41 AM
02/22/10 12:41 AM
indiana
moparbrown14 Offline
indiana
you could always put a rear end out of a b body, the housing is an inch and a half narrower mine is out of a 67 gtx
Re: 10 Inch Rear wheel on stock 71Challenger? [Re: moparbrown14] #620632
02/22/10 12:43 AM
02/22/10 12:43 AM
indiana
indiana
i run 10 inch wheels with i think 4 and a half back spacing with 11.5 x 29.5 phoenix tires car runs 10.90s
Re: 10 Inch Rear wheel on stock 71Challenger? [Re: MoparDonny] #620633
02/22/10 10:09 AM
02/22/10 10:09 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
* 15 x 8 w/ 4.5" backspace or 15 x 10 w/ 5.5" backspace using 275/60R15 tire *
Re: 10 Inch Rear wheel on stock 71Challenger? [Re: BradH] #620634
02/22/10 01:46 PM
02/22/10 01:46 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
You should be fine with a 15 x 10" wheel. I just mocked up my Challenger with the Doctor Diff 1-1/2" relocation kit & Cal-Tracs this weekend. Its going to be close but I think it will work. I am running a 315/65/15 M/T Drag radial (30" x 13-1/2")on a Weld 15" x 12" Magnum 2.0 rear wheels with a narrowed Dana 60. It looks like I'll only have about 1/4' to the leafs & a 1/4 to the wheel well lip. like i said it close but it should work. Drag Radials don't grow like a slick does.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 10 Inch Rear wheel on stock 71Challenger? [Re: MoparDonny] #620635
02/22/10 04:55 PM
02/22/10 04:55 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Can it fit without a Dr.Diff offset hanger kit....
He said WITHOUT a doctor offset hanger kit....I don't think it will fit with a big tire....but it might with a 275 tire.
I run 10" wheels with a 1-1/4" DR diff offset hanger kit and 10" wide tire (28x12.50 ET STREET) and they are pretty close to the spring.
I did try the same tire on an 8" wheel with no offset hangers and had almost no room to the springs either...so I had to add the offset hangers. My 295-50-15's Cooper cobras fit with 8" wheels though and no offset hangers.
Re: 10 Inch Rear wheel on stock 71Challenger? [Re: moparbrown14] #620636
02/22/10 08:59 PM
02/22/10 08:59 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
Or A body 8 3/4
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
