Best street / strip fuel pump for 600 HP?
#620466
02/21/10 11:44 PM
02/21/10 11:44 PM
Posts: 2,886 Bowling Green KY / Nashville, ...
300by500
It's time to get working on the Barracuda again, it'll probably see mostly street use with some trips to the track now and then. 4.15 crank 440, .040 over, around 498 inches. 11:1, hydraulic cam, prepped Edelbrocks, Holley 950 HP, I'm guessing it'll be in the 550-570 horsepower range. I'm looking for a pump that will handle the fuel needs of the motor, be dependable, and be quiet as possible. Any suggestions?
Re: Best street / strip fuel pump for 600 HP?
[Re: 300by500]
#620467
02/21/10 11:50 PM
02/21/10 11:50 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
For a good, reliable and quiet electric pump, you can't go wrong with the Mallory 140. More than enough to handle 600 horses and then some.
2 kids and a dog
[Re: jamesc]
#620470
02/22/10 02:09 AM
02/22/10 02:09 AM
Posts: 486 IL
knyech1
IL
That's what I have too.
[Re: BloFish]
#620475
02/22/10 01:41 PM
02/22/10 01:41 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I really got to dislike the Mallory 140 pump, I have been using it on a daily driver..Its on my 01 Dodge Truck that see's hundreds of miles a week.. The pump eats brush's like no other.... I actually keep brush kits in the truck at all times. I know a race car wont see as much driving, but just proves the pump wont last for the long haul. I have also polished the commutator ans slip ring to keep it from being so bad.. I now can get 5-6 months before replacing.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: 300by500]
#620476
02/22/10 04:29 PM
02/22/10 04:29 PM
Thumperdart
State of confusion
I`m running the new Holley billet 150 series pump.....fairly quiet, fair priced but not totally sure it`s enuff for my car as of yet.
[Re: 23T Hemmee]
#620477
02/22/10 04:36 PM
02/22/10 04:36 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
The Clay Smith pump is very good. I used one many years ago with a 12:1 440 with two 660 center squirter on a tunnel ram. Also Race Pumps make a piston pump that works very well.
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
[Re: Quicksilver440]
#620479
02/22/10 04:57 PM
02/22/10 04:57 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
have had good luck with the holley billet 150 on a couple of street/strip cars,mine is a daily driver.only light noise but on a hot day after an hour or so can get a little noisey.(deadhead set up) also know a couple that died ? always been happy with mallory's Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#620480
02/22/10 05:26 PM
02/22/10 05:26 PM
Posts: 11,732 Portage,michigan
B3422W5
Portage,michigan
Holley black is more than equal to the task.
[Re: 300by500]
#620481
02/22/10 05:38 PM
02/22/10 05:38 PM
Posts: 5,080 organ
maximum entropy
organ
don't be afraid to try a mechanical pump. i got so sick of electric pumps, i put a carter race mechanical in and never looked back. that was close to ten years ago, and still going strong. my car runs tens, and fuel pressure is rock solid through the entire run. i never could say that about any electric pump i ever ran.
[Re: maximum entropy]
#620482
02/23/10 12:30 AM
02/23/10 12:30 AM
300by500
After looking at posts on several sites, I'm really leaning toward a Clay Smith mechanical. Since it's a street-strip car, I'm not worried about losing a few HP to drive the pump. Sounds like the perfect setup for my HP and intended use...
