Re: Trans is leaking prior to initial startup, why?
[Re: wh23g3g]
#620356
02/21/10 09:54 PM
02/21/10 09:54 PM
RapidRobert
The 16.25 qt figure is not right. Not sure how much it needs now but no damage has been done, Start it up & keep adding fluid until it is full
[Re: forphorty]
#620357
02/21/10 09:57 PM
02/21/10 09:57 PM
Posts: 2,111 Bowie, MD
Reggie
Bowie, MD
I would think you could fill it to the gills and it shouldnt leak out just sitting. Drivers side? might be leaking at the gear selector seal or at cooler line fittings.
Ditto. Look for the source of the leak and then you'll have an idea what the problem is.
[Re: wh23g3g]
#620358
02/21/10 10:12 PM
02/21/10 10:12 PM
Posts: 8,506 Candler,NC / Myrtle Beach, SC
JDMopar
I'll bet it's leaking out of the vent behind the torque converter. I over filled one once, and that's what it did. You should only half fill a new transmission till startup, and then fill it to the proper level with it warm and in neutral after startup. If it's leaking from around the dipstick tube, the o-ring isn't seated properly. Good luck.
[Re: JDMopar]
#620359
02/22/10 01:55 AM
02/22/10 01:55 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
It shouldn't take but 10 qts. max, but i'll bet its only 9, 5 for the pan, 4 for the converter, you most likely have a leaky "selector shaft seal", just crawl under it & feel around the shaft, if its leaking, you will know it, i wouldn't think 6-7 qts. would leak prior to start-up if all seals are good.
[Re: wh23g3g]
#620360
02/22/10 01:58 AM
02/22/10 01:58 AM
joedust451
super gas
super gas
Branson, Mo.
I'm finishing up the details on my 73 Charger 400 refurbish. I'm adding the transmission fluid to my remanufactured 727. It's got a new converter and I added almost a quart when I installed the transmission. I then added 7quarts through the fill tube. Then I noticed a few minutes later on the driver's side transmission pan flange the fluid was dripping out. It leaked about a quart and then has stopped dripping. I know one veteran mechanic that runs a shop told me only to put about 5 or else the fluid will bleed out since the pump isn't turning. Do you think this is what happened? The 73 owner's manual says 16.25 quarts total. So I had almost 8. Will the converter scream when I initially start up the motor?
I'll bet that was 16.25 PTs., not QTs.
[Re: joedust451]
#620361
02/22/10 02:03 AM
02/22/10 02:03 AM
RapidRobert
You'd want to add a certain amt (a qt or 2 I'd guess) to the TC and smear some on the OD of the snout before installation then several quarts in the dipstick tube then immediately start adding qts when the eng fires. why several helpers are needed on a new eng/cam breakin.
[Re: wh23g3g]
#620363
02/22/10 06:18 PM
02/22/10 06:18 PM
Posts: 26,008 Rio Linda, CA
John_Kunkel
Rio Linda, CA
In a standard pan, 6 quarts is the correct initial fill with a dry transmission, any more can run out the vent in the front pump.
[Re: DAYCLONA]
#620366
02/22/10 08:14 PM
02/22/10 08:14 PM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
Jon the trannys capacity is 16 pints not qts,...2 pints equal a quart,...so 8 qts is enough, chances are it the selector shaft that's leaking on the drivers side just above the pan rail, if so, you'll need to drain the pan, and drop the valve body to R&R
There is a tool made that can remove the seal without removing the valve body (if that's a problem). It's KD tools #2392and this is it:
[Re: wh23g3g]
#620367
02/22/10 08:16 PM
02/22/10 08:16 PM
Pat_Whalen
super gas
super gas
Mesa, AZ
It's got to be from the vent then. Overnight I checked and the puddle was a little bigger, probably 2-3 quarts now. But I've been working on the engine bay all day and it's not dripping anymore and the puddle isn't getting any larger. That's what a mechanic around here that I know told me would happen if I tried to put all 8 quarts in. I didn't put 16 quarts in, that's what I thought 2 pints in a quart so I put 8 quarts in.
I don't think 7 quarts will be enough to fill a trans case up to the vent (at the top of the pump). That's an awful lot of room to fill before you get up there.
[Re: wh23g3g]
#620369
02/23/10 01:52 AM
02/23/10 01:52 AM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
The shift shaft seal is on of the places I would look at. My shaft never really showed the leak unless I parked it on a incline or over filled it. As soon as I over filled it... click to enlarge. Click the picture in the newly opened box to see larger view. I used the same tool Pat used to change it. Easy 30 minute job once you have all the tools. Basically if you take a look at your pan, you can clearly see it cannot hold 9 quarts of oil at once, it must be distributed thru out the trans. The Shift shaft seal is one of the first locations to be covered when the fluid level rises above the pan.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
