shaker base plate seal #620313
02/21/10 09:37 PM
02/21/10 09:37 PM
Canada
sassysixpack1 Offline OP
Canada
Does anyone have a good picture on the proper way a shaker base\hood seal is installed ? I have a repro seal (don't even know where it is from)and it doesn't seem to fit right no matter which way it is put on.
Thanks !
Re: shaker base plate seal [Re: sassysixpack1] #620314
02/21/10 10:08 PM
02/21/10 10:08 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Both the air door and adapter ring seal gets glued with yellow weatherstrip adhesive..The seal's glue joint gets placed near the bellcrank...Missing from the pic is the cloth tape that covers the seal's glue joint...
Re: shaker base plate seal [Re: screamindriver] #620315
02/21/10 10:15 PM
02/21/10 10:15 PM
Green Lane, PA
sawdust Offline
sawdust  Offline
Green Lane, PA
Correct on the "Yellow death" adhesive, 3M Super weather strip adhesive appears close and possibly correct as it probably browned over time.
One thing is most of the original shaker gaskets also had a tape over the glue joint, though some earlier ones did not
Also, not to nit pic, but the air door seal looks a bit tall and narrow?
Re: shaker base plate seal [Re: screamindriver] #620316
02/21/10 10:16 PM
02/21/10 10:16 PM
Fort Workin Tx
Day2Runner Offline
Day2Runner  Offline
Fort Workin Tx
does the seal have a staple at the glue joint toward the bottom ??
Re: shaker base plate seal [Re: Day2Runner] #620317
02/21/10 10:19 PM
02/21/10 10:19 PM
Green Lane, PA
sawdust Offline
sawdust  Offline
Green Lane, PA
Cannot say I have ever seen that but maybe Scott Smith can verify. The originals I have do not show any evidence of a staple, though anything could be possible.
Re: shaker base plate seal [Re: Day2Runner] #620318
02/21/10 10:28 PM
02/21/10 10:28 PM
Harrisburg, Pa.
Harrisburg, Pa.
It's been a while since I've restored the adapter ring but I somewhat remember some{I did'nt put any back on}staples...Old age and too much info in my head.. ...And yes that door seal does'nt even have the texture the original did...But I used it anyway... ...Another wonderful repop item...Although I did'nt slop the yellow glue all over the parts like the factory did...
Re: shaker base plate seal [Re: screamindriver] #620319
02/21/10 10:33 PM
02/21/10 10:33 PM
Canada
Canada
Thanks, the seal I have does not look the same as the one in the picture. How much of the seal is actually glued to the base, as this one only allows for maybe a quarter inch.
Thanks again.
Re: shaker base plate seal [Re: screamindriver] #620320
02/21/10 10:40 PM
02/21/10 10:40 PM
Green Lane, PA
sawdust Offline
sawdust  Offline
Green Lane, PA
Sounds like you need to upgrade your hard drive and maybe RAM?
Maybe a couple beers would help with the sloppy workmanship for gluing?
Re: shaker base plate seal [Re: sassysixpack1] #620321
02/21/10 10:45 PM
02/21/10 10:45 PM
Green Lane, PA
sawdust Offline
sawdust  Offline
Green Lane, PA
I will post some more underside pictures of an NOS seal installed on an original Shaker ring for reference. There should be more than a 1/4 inch on the underside to glue though, maybe 1/2 to 5/8.
For now this is what I have from the topside.
Re: shaker base plate seal [Re: sawdust] #620322
02/21/10 11:02 PM
02/21/10 11:02 PM
Harrisburg, Pa.
Harrisburg, Pa.
I don't have an underside pic of my NOS seal either....But here's a pic that Scott Smith had posted in a previous thread a few years back when we were discussing some shaker related facts...You definitely should have more than 1/4 inch wrapped around the underside of the ring...This one is all original...I've heard some of those aftermarket seals fit poorly...
Re: shaker base plate seal [Re: screamindriver] #620323
02/21/10 11:14 PM
02/21/10 11:14 PM
Canada
Canada
Thanks guys, I got it. Had to take a razor blade and "release" more of the flap that glues to the bottom of the base.
Re: shaker base plate seal [Re: sassysixpack1] #620324
02/22/10 12:37 PM
02/22/10 12:37 PM
Anchorage, Alaska
Iceman01 Offline
Challenged
Iceman01  Offline
Challenged
Anchorage, Alaska
So extending this question to the next step in the process, what is the best way to do the actual glueing? I need to do mine soon and from the test fitting it appears I'll need clamps. Is that correct?
Until total honesty is on the table, we're not even talking about reality...
Re: shaker base plate seal [Re: Iceman01] #620325
02/22/10 01:17 PM
02/22/10 01:17 PM
Far Northeast.
mymcodebee Offline
mymcodebee  Offline
Far Northeast.
Clothespins.
Works great on the trunk seals too.
Re: shaker base plate seal [Re: mymcodebee] #620326
02/22/10 09:19 PM
02/22/10 09:19 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
my original seal split was in the back...aar's had it on the side also...
Re: shaker base plate seal [Re: AARCONV] #620327
09/13/12 02:21 PM
09/13/12 02:21 PM
Wisconsin
Mopar_Mudder Offline
Wisconsin
An old thread but alot of good info here. I have a couple of questions:
1: My seal is not preglued at the joint, I have to cut to length and then glue it. Is it better to cut to length and glue the joint first, or should I cut and glue the joint after I get it glued to the adapter?
2: is the seal glued to both the top and bottom of the adapter ring? Or just one or the other?
3: where can you get the air door seal? I didn't know there was suppose to be one and don't remember seeing one for sale.
1971 Hemi Cuda 2005 SRT-10 Regular Cab Flame Red. 12.771 @ 109.67<---TIME SLIP--Video
Re: shaker base plate seal [Re: Mopar_Mudder] #620328
09/13/12 02:50 PM
09/13/12 02:50 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
Year One has the air door seal - under $10 IIRC
Re: shaker base plate seal [Re: YYZ] #620329
09/13/12 08:10 PM
09/13/12 08:10 PM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
Original door seal
MMC/ ICCA Detroit. The Motor City or where ever there is Mopars
Re: shaker base plate seal [Re: sawdust] #620330
09/13/12 08:15 PM
09/13/12 08:15 PM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
Tape
Re: shaker base plate seal [Re: MMC Detroit] #620331
09/14/12 01:46 AM
09/14/12 01:46 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The last two posts show all of the correct details
Re: shaker base plate seal [Re: ScottSmith_Harms] #620332
09/14/12 09:49 AM
09/14/12 09:49 AM
Ontario, Canada
mccannix Online content
mccannix  Online Content
Ontario, Canada
For restoration accuracy the small seal is to be glued together at the rear of the opening as seen in the photos provided and as per the original drawing
