70 dart wont run #620165
02/21/10 07:47 PM
02/21/10 07:47 PM
littlestown pa
dustpan man Offline OP
littlestown pa
ok the car won't run points conduncer cap roter pulgs wires are all new and set to factory spects the carb I just rebuilt it starts but runs ruff then cuts out its getin gas the pumps working just fine idk
Re: 70 dart wont run [Re: dustpan man] #620166
02/21/10 07:50 PM
02/21/10 07:50 PM
scratchnfotraction Offline
ballist resiter
and double check the condencer...i just went thru 3 new ones...
Re: 70 dart wont run [Re: dustpan man] #620167
02/21/10 10:08 PM
02/21/10 10:08 PM
MNobody Offline
MNobody  Offline
Are the floats set right? make sure they aren't sticking either. I've never seen a bad ballast make a car run rough it usualy won't run or will fire in the start position and quit in the run or vice versus. Double check the plug wires for correct hookup and how is the timing? Idle mixture screws adjusted right?
Re: 70 dart wont run [Re: MNobody] #620168
02/22/10 04:38 PM
02/22/10 04:38 PM
littlestown pa
littlestown pa
the floats is set right they aren't sticking either timing is good Idle mixture screws idk dont it have to run to check that
Re: 70 dart wont run [Re: dustpan man] #620169
02/22/10 04:40 PM
02/22/10 04:40 PM
littlestown pa
littlestown pa
it pops out the carb and ehaust when it does run
Re: 70 dart wont run [Re: dustpan man] #620170
02/22/10 04:44 PM
02/22/10 04:44 PM
its not running,correct?
it just turns over and no start,correct?
does it fire in the start mod and die when you go to run mode?
check fire order,pull coil wire from dist and check for fire,pull plug wire and check for fire
air
fuel
fire
should run or try to run at least
Re: 70 dart wont run [Re: scratchnfotraction] #620171
02/22/10 04:53 PM
02/22/10 04:53 PM
What engine/When did the problem start/dist moved/taken out?/did it run before/what changed since. More info needed.
Re: 70 dart wont run [Re: RapidRobert] #620172
02/22/10 04:57 PM
02/22/10 04:57 PM
I gather they did a tune up and now it no worky
