Please post pics of your Street rod motors!
#62003
05/23/08 09:53 AM
05/23/08 09:53 AM
Posts: 9,857 Cambridge Idaho
RUMBLON
Cambridge Idaho
Can you guys please post some pics, specs and performance/mileage of your street rod motors. Also, is there anyone making any aftermarket street rod style parts for the LA motors? seems like a decent market to do since there are becoming more popular. LAWFISH
Re: Please post pics of your Street rod motors!
[Re: Fargo Freek]
#62006
05/28/08 10:17 AM
05/28/08 10:17 AM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
stock Dakota 318. Picture is from 97 when I put the body on the chassis. Still haven't got much more done. It's not pretty, but I hope that it moves the car and gets good MPG. The 40 should be lighter, and with 3.91 and OD should be able to get off the line and cruise down the road. When I checked into speed equipment, a few told me that you had to take it easy if you keep the stock computer. free up the exhaust some, maybe a bit bigger on the cam, and a bigger throttle body, and you are close to the edge. Of course, that was years ago, and there have been many changes since. I figure stock it will be enough for at least 95% of my driving. http://www.nicksgarage.com/jh/2006-12-11/40engine.JPG
[Re: RodStRace]
#62007
09/18/08 12:24 AM
09/18/08 12:24 AM
Posts: 3,445 N.Wilkesboro,NC
DusterKrazy
N.Wilkesboro,NC
Wow...where's all the rest of the rod engines?? Here's one I got to cracking on last weekend. Very cheap build. It's a 1984 318 from a diplomat. We left the bottom end stock and inspected everything real good. Bearings looked great and the cylinders barely had any wear at all. Got a polished weiand intake for $75 from a member here and a $50 mopar '68 340 4speed cam (450/455 lift), Then I put on a set of shaved 360 heads, will also feature a set of headers I got for free! Check out the vintage weiand valve covers I traded for. Other tidbits are a 600 holley and a double roller timing chain Check out the air cleaner! Hubcap style
[Re: John_Kunkel]
#62012
09/23/08 07:53 AM
09/23/08 07:53 AM
Posts: 1,511 AZ
Mike P
AZ
Here's mine....got it running on the test stand a couple of weeks ago. It will eventually go into a 37 Dodge Pickup at some point after my new shop is built. 331 from a 55 New Yorker. First link is description of the engine and mods. Second is of it running. http://www.youtube.com/watch?v=zkFIowdvfGohttp://www.youtube.com/watch?v=x5VEbByTEUc
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
[Re: B1arno]
#62016
10/03/08 06:14 PM
10/03/08 06:14 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
472 in my still unfinished Allsate. MP heads, comp 612" 280* @ .050 solid, 11-1 JE, Indy intake, 950 race Demon carb, Milodon external pan. Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: RUMBLON]
#62020
02/23/09 02:17 AM
02/23/09 02:17 AM
Posts: 1,417 MS
redex79
MS
No specs yet. Just started mocking up. Poly 318 in a 40 Desoto.
Truckin Weekend ! 70 Dodge Dart Swinger 11 Ram 1500 Laramie 4x4 21 Dodge Durango GT
[Re: Lugnutz]
#62021
02/23/09 02:18 AM
02/23/09 02:18 AM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
It won't fit a Poly, as the Poly's are I-E-I-E-I-E-I-E and the Wedges are E-I-I-E-E-I-I-E. There was a bolt hole issue with the early 273's (different angle of the bolt holes or something like that) but there is a good chance that with little to no modification it would work on a 318 head as well. That said, if you really want to use it, I would consider something along the lines of hotroddave40's 318 build...but you can choose how "economical" you want to make it as far as cam/carbs are concerned. A couple 450cfm vacuum secondary 4-bbls would be a max effort, but a 302 headed 318 is capable of some decent snort without breaking the bank.
Just a thought...
2 Demons...no, not my kids!
