Re: 4" stroke vs 4.125" stroke in small block stroker
[Re: kielbasa]
#619993
02/21/10 07:01 PM
02/21/10 07:01 PM
Posts: 2,489 Pacifica, CA
Devilbrad
Pacifica, CA
for the sake of conversation, let's assume there is no price difference between the two....... the more I think about it, yes, I agree, it really wouldn't be "that much milder".
There is no price difference between the two: https://board.moparts.org/ubbthreads/show...e=0#Post5728574 RyanJ and most of the smart small block guys on here really like that crank. If it costs the same, go with the bigger CI's. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: RyanJ]
#619995
02/21/10 07:57 PM
02/21/10 07:57 PM
Posts: 1,880 USA
Ron Silva
USA
I did a 4" stroke in a 71 360 block and in my opinion the rod bolt clearance notches at the bottom of the cylinder were kind of close to the water. I know for a fact I was using a 2.100 chevy pin and I think I had an Eagle rod and it probably had a 7/16 bolt. It's been a long time ago before anybody was doing it and there were no kits or mopar cranks etc. Eagle rods just came out then too for SB chevy.
So, if you do not have an R3 block you better be carful when you grind. I just did the welding rod down the water jacket pinching with my thumb and then slid it down inside the cylinder. Maybe my perceptive was wrong, but it looked close. Many say it is a non issue.
SRT DEMON ONE SEAT
[Re: Ron Silva]
#619996
02/21/10 08:01 PM
02/21/10 08:01 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
it will depend a lot on block/rod combo my X block with Scat H beams with 7/16 bolts cleared with out any grinding at all. I did go ahead and grind a little anyway because I just wanted a little more clearance than what was there but they did clear to begin with.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: S/ST 3040]
#619998
02/21/10 10:48 PM
02/21/10 10:48 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
If cost is not the factor between the two choices,go for the longer stroke.In a street car,you can't really go wrong with more torque. Less convertor,gear,and it still pulls like crazy. Just watch it on your choice of cams,these longer strokes can eat up a lot of duration and still idle well,talk to an expert if need be. ![](/ubbthreads/images/graemlins/Twocents.gif)
