Re: Can slotted rotors be turned?
[Re: dart_sportsatellite]
#61992
05/23/08 02:50 PM
05/23/08 02:50 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Yes they can be turned but will a shop turn them? That is the question. It is hard on the carbide tip when it gets to the slot and back onto the rotor. Sometimes the carbide tip breaks or skips on the rotor. Many places will not turn your rotor because of this. Carbide tips are not cheap.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#61993
05/23/08 08:23 PM
05/23/08 08:23 PM
Having turned a few (more than a thousand) rotors and drums in an earlier life, I would think not.
Seems to me the slots/ holes in a vented rotor would be deadly to tools, unless you have a grinder, and few shops do. Grinding them would take a LONG time.
(What do they cost to replace?)
#61996
05/23/08 10:44 PM
05/23/08 10:44 PM
Posts: 10,560 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have turned them before with no trouble at all. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
#61999
05/23/08 11:33 PM
05/23/08 11:33 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
The whirrr is a common complaint, no harm other then the noise Make sure they're installed on the correct side of the car, they should be directional
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
