Re: boosted cams,post yours.
[Re: hemidup]
#618508
03/24/10 07:44 PM
03/24/10 07:44 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
There is a defined range for rpm/ duration. You are operating above and beyond that range. Supercharging or turbocharging helps to stretch that range. It lets you "get away" with things that you can't with a N/A motor. In your case, you're "getting away" with alot. 5000+ lbs and almost in the tens,,,, you're doing good. Treat your engine to a little breathing. Go with at least 230 @050. You will be pleasantly suprised.
[Re: furydave]
#618512
07/31/10 01:12 PM
07/31/10 01:12 PM
Posts: 63 indiana PA
moparbob498
indiana PA
custom grind Crane--#68R000029 R-286/4668-2S3-12 lash .026 int.---.030 exh. @.050- int. opens 34 BTDC CLOSES 72 ABDC 286* DUR. EXH. OPENS 88 BBDC CLOSES 38 ATDC 306* DUR 112* CENTERLINE INSTALLED AT 108* ADVERTISED .700 INT.---.715 EXH. 326*--356* MAX RPM 8600 its my first roller and is unreal
mopar or no car
[Re: moparbob498]
#618513
07/31/10 08:53 PM
07/31/10 08:53 PM
Posts: 96 Australia
gg408
Australia
Solid flat tappet. single pattern 236 @ .050". .526" lift with 1.5 rockers 114 lsa its a 410 w2 headed small block with a BW S480 turbo, hoping to make around the 850/900 fwhp. Lets see what happens. ![](/ubbthreads/images/graemlins/grin.gif) gg408 ![](/ubbthreads/images/graemlins/beer.gif)
