Brake pad recommendations for Viper brake conversion? #617505
02/18/10 11:39 PM
02/18/10 11:39 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Okay, I'm down to the last bits and pieces for my early Viper caliper/11.75" conversion on my Dart. Got the spindles, got the ARE adapter kit, got the rotors, got new bearing, caliper bolts, seals, and even new dust caps. All that's left are the hoses, pads and pad hardware. Anyone have any recommendations as to a suitable pad. I'm thinking maybe Baer DecelaPads. Or maybe OEM Mopar? The Baer stuff doesn't come with the pad hardware and I can't find a separate source for it. Any suggestions?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Brake pad recommendations for Viper brake conversion? [Re: MadMatt] #617506
02/19/10 12:05 AM
02/19/10 12:05 AM
AndyF Online content
AndyF  Online Content
For street driving I'd go with the OEM Mopar stuff. For racing maybe step up to a slightly higher temp pad.
If you check on a Viper forum you might find a different recommendation. Some folks really like the EBC pads for example.
Re: Brake pad recommendations for Viper brake conversion? [Re: AndyF] #617507
02/19/10 12:06 AM
02/19/10 12:06 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Thanks, I was leaning OEM Mopar 'cause it gets me the hardware, too.
Re: Brake pad recommendations for Viper brake conversion? [Re: MadMatt] #617508
02/19/10 12:24 AM
02/19/10 12:24 AM
We road race with OEM pads and don't have any issues. This isn't super serious class racing but the car is still doing 120+ mph each lap before slowing down to 40 or 50 for a tight curve. That is fairly heavy use of the pads and the OEM stuff seems to hold up fine.
I'd suggest running OEM stuff until you prove that it isn't working (fade) and only then step up to an aftermarket pad. I'm guessing that the OEM pads have more engineering time invested in them and are built to higher quality standards than any of the aftermarket pads.
Re: Brake pad recommendations for Viper brake conversion? [Re: AndyF] #617509
02/19/10 12:51 AM
02/19/10 12:51 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Matt, are you putting that stuff together soon? I'd like to see that Viper stuff in person up close before you install it.
Re: Brake pad recommendations for Viper brake conversion? [Re: AndyF] #617510
02/19/10 12:53 AM
02/19/10 12:53 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
You wouldn't happen to have the part # for the pads would you? I've had some miserable experiences with my local dealers. If I ask them to look it up I may end up with pads for a '84 Dodge Aries.
Re: Brake pad recommendations for Viper brake conversion? [Re: MadMatt] #617511
02/19/10 01:06 AM
02/19/10 01:06 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Did you call Troy (805) 578-8144 over at Simi Dodge? He will personally take care of you. You can PM him here too.
Re: Brake pad recommendations for Viper brake conversion? [Re: autoxcuda] #617512
02/19/10 01:10 AM
02/19/10 01:10 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Duh! I forgot Troy went over to Simi Dodge.
I'll give him a shout tomorrow.
Re: Brake pad recommendations for Viper brake conversion? [Re: MadMatt] #617513
02/19/10 01:20 AM
02/19/10 01:20 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I pm'd him. He'll probably respond here soon.
Re: Brake pad recommendations for Viper brake conversion? [Re: autoxcuda] #617514
02/19/10 01:25 AM
02/19/10 01:25 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Jeez, I was just looking around online and it looked like a set of OEM pads was like $200!! Could that be right??
Re: Brake pad recommendations for Viper brake conversion? [Re: MadMatt] #617515
02/19/10 01:28 AM
02/19/10 01:28 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I've heard OE SRT-8 Brembo pads are big bucks like that. Doesn't surprise me.
Re: Brake pad recommendations for Viper brake conversion? [Re: autoxcuda] #617516
02/19/10 01:30 AM
02/19/10 01:30 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
If that's the case I may have to go aftermarket. The Baer pads are only 56 bucks from Summit. I just gotta figure out where to get the pins and anti-rattle clips.
Re: Brake pad recommendations for Viper brake conversion? [Re: MadMatt] #617517
02/19/10 02:01 AM
02/19/10 02:01 AM
Temecula, CA
Dukes69 Offline
Dukes69  Offline
Temecula, CA
I recommend EBC yellow pads. Excellent cold bite and phenomenal hot bite.
Re: Brake pad recommendations for Viper brake conversion? [Re: Dukes69] #617518
02/19/10 01:56 PM
02/19/10 01:56 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
Hello Everybody!! I would go aftermarket with those pads. Dealer cost on those pads are over $200.00 That is just stupid!!
Wish I could help but sorry.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Brake pad recommendations for Viper brake conversion? [Re: Troy] #617519
02/19/10 02:12 PM
02/19/10 02:12 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
Troy, you help out more than you know.
Re: Brake pad recommendations for Viper brake conversion? [Re: Troy] #617520
02/19/10 02:46 PM
02/19/10 02:46 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Troy,
Maybe you can help. Is there a separate part number(s) for the pad hardware? I need the pad retaining pins and the anti-rattle clips.
Re: Brake pad recommendations for Viper brake conversion? [Re: Dukes69] #617521
02/19/10 03:07 PM
02/19/10 03:07 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Re: Brake pad recommendations for Viper brake conversion? [Re: Troy] #617522
02/20/10 03:26 PM
02/20/10 03:26 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
That's one down side to my big AMG brake conversion. The pads retail for $276. The rotors are $376 each.
I need to keep my job at Mercedes to help pay for those things.
- Stu Harmon
