Re: 72 charger gas tank?
[Re: Flatblack]
#616671
02/18/10 02:48 AM
02/18/10 02:48 AM
Posts: 1,647 IL
71383beep
IL
Yep, that's the vapor separator. Each of the 4 hoses going to it should go to 4 corners of the tank. It is basically an emissions piece. and it does help to provide proper venting of the tank.
Without proper venting the tank will go to vacuum and you can get an air bubble in your fuel line which can stop you cold.
A 5th line should connect with the vapor return line from the motor.
'73 GK6 Challenger Rallye - 340 4-Speed
[Re: Flatblack]
#616675
02/18/10 06:46 AM
02/18/10 06:46 AM
Posts: 48 Los Angeles
Hazwoy
Los Angeles
Check your FSM. Fuel cap is "pressure-vacuum relief" type. cap is vented to allow air in but won't allow air out unless it reaches a certain pressure so essentially tanked is vented thru fuel cap if you choose to block off vent tubes.
Goofed when I first posted this. Cap is "vacuum-pressure release" NOT "pressure-vacuum relief". Sorry if this led to any confusion.
