Cheap suspension upgrades? #616506
02/17/10 11:25 PM
02/17/10 11:25 PM
ohio
m300b Offline OP
m300b  Offline OP
ohio
Want to improve handling for a 66' B body 383 4-speed on the cheap. A street car but I want it to feel like the newer cars. Moog offset upper control arm bushings or tubular arms? (looking to get about 4 degrees + caster?) Front & rear sway bars-Addco or Mopar Performance? FirmFeel power steering #3 with long pitman?
Mark
Re: Cheap suspension upgrades? [Re: m300b] #616507
02/17/10 11:40 PM
02/17/10 11:40 PM
IN
ahy Offline
ahy  Offline
IN
In bang for the buck I would say
1. Decent shocks (KYB's have done well for me)
2. Basic rebuild (bushings, tie rod ends ect). Rubber is the safest bet for lower control arm bushings
3. Front sway bar
4. Frame connectors
5. Bigger T bars. 1" seems to work well w/o too much harshness
6. Offset bushings
7. Or tubular control arms
A level II or III Firm Feel box woul be nice with any of these.
Re: Cheap suspension upgrades? [Re: m300b] #616508
02/18/10 04:21 AM
02/18/10 04:21 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Mark
-Stock A-arm with moog offset bushings. No need for adjustable strut rods. If you want to make extra sure to get a lot of caster just cut/shave 3/16" of the rear poly strut bushing and strut sleeve to make it stock thickness: http://www.heritech.org/cuda/bushings.html
-1.00" Torsion bars that Just Suspension is blowing out for like $159/pr. I think the sale ends soon, so hurry up.
-On the cheap Addco sway bars for around $100 ea on ebay. But the front attachment setup really stinks. Firm Feel, Hellwig, Hotchkis are all very good. Go with what fits your budget and the detail features you like.
-Make sure the long pitman works with your headers or has room behind you current headpipe. IIRC, its sets over 1" further back. Comfirm distance with Firm Feel.
Re: Cheap suspension upgrades? [Re: autoxcuda] #616509
02/18/10 06:56 AM
02/18/10 06:56 AM
ohio
m300b Offline OP
m300b  Offline OP
ohio
Re: Cheap suspension upgrades? [Re: m300b] #616510
02/18/10 07:51 AM
02/18/10 07:51 AM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
Sale on $159 just went to $179, so it's still a good price.
You'll do alot with their suggestions on suspension. Also look into rear leaf springs, they won't hurt your handeling either.
Re: Cheap suspension upgrades? [Re: migsBIG] #616511
02/18/10 11:12 AM
02/18/10 11:12 AM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
I just ordered a set of UCA's at $159 with free shipping over the phone. Tell them you saw it for $159 and they may honor it.
I also ordered two sets of 1" t bars because $159 per set is a STEAL.
They shipped it all for free too. How in the heck can they do that?
Re: Cheap suspension upgrades? [Re: m300b] #616512
02/18/10 01:55 PM
02/18/10 01:55 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
A set of sway bars will give you the best handling improvement for your money assuming the suspension bushings are in good shape.
Re: Cheap suspension upgrades? [Re: Lefty] #616513
02/18/10 08:20 PM
02/18/10 08:20 PM
Ball Ground, Georgia
Dixie Offline
Dixie  Offline
Mark,
We have adjustable strut rods for $120 pair, or $150/pr with bushings. They are larger than stock and offer over an inch more of adjustment.
Please let me know if you have any questions.
Thanks,
Randy
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: Cheap suspension upgrades? [Re: autoxcuda] #616514
02/19/10 08:24 PM
02/19/10 08:24 PM
ohio
m300b Offline OP
m300b  Offline OP
ohio
Are there any sway bar fitment issues when using disc brakes?
Re: Cheap suspension upgrades? [Re: m300b] #616515
02/19/10 10:28 PM
02/19/10 10:28 PM
Dixie Offline
Dixie  Offline
If you're asking about our product, no there isn't.
Re: Cheap suspension upgrades? [Re: m300b] #616516
02/20/10 12:00 AM
02/20/10 12:00 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
If you are running a 66 K-member that has the wide style sway bar you should run the calipers to the rear of your spindle.
You can shorten the sway bar links, but I think it's a cleaner install to just put them in the rear.
Re: Cheap suspension upgrades? [Re: autoxcuda] #616517
02/20/10 09:41 AM
02/20/10 09:41 AM
ohio
m300b Offline OP
m300b  Offline OP
ohio
I have a 68 k member in the Belvedere convertible. (car was a slant 6). Car is completely stripped (on a rotisserie) and all I have done is welded in frame ties. Car will be a Sunday driver that I want to feel more "modern".
Would it be wise to use the weld-on control arm sway bar brackets from Hotchkis? Looks like a cheap & clean install.
Thanks Guys
Re: Cheap suspension upgrades? [Re: m300b] #616518
02/20/10 01:31 PM
02/20/10 01:31 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thanks Guys
Good think you got a 68 K-member with the better thru bolt idler arm. Great idea to put subframe connectors in a convertible.
I think the $30 66-69 Hotchis sway bar adapters are a great deal and make for a install the looks stock unless you're eyeballs are under 2' away from you LCA's under your car.
On a conv. cruiser, I wouldn't go any more that 1" T-bars.
Re: Cheap suspension upgrades? [Re: autoxcuda] #616519
02/20/10 07:55 PM
02/20/10 07:55 PM
ohio
m300b Offline OP
m300b  Offline OP
ohio
Thanks again
