Page 1 of 3 1 2 3
Post deleted by Defbob #616328
02/17/10 10:13 PM
02/17/10 10:13 PM
Anonymous OP
Anonymous OP
Re: Let's see those Roots blower cars!!! #616329
02/18/10 03:20 AM
02/18/10 03:20 AM
everywhere
stonecold Offline
stonecold  Offline
everywhere
70 HEMI GTX
Re: Let's see those Roots blower cars!!! [Re: stonecold] #616330
02/18/10 03:21 AM
02/18/10 03:21 AM
everywhere
stonecold Offline
stonecold  Offline
everywhere
the "MILL"
Re: Let's see those Roots blower cars!!! [Re: stonecold] #616331
02/18/10 07:36 AM
02/18/10 07:36 AM
ky
headhunter Offline
headhunter  Offline
ky
killer blower cars makes me miss my old car
Re: Let's see those Roots blower cars!!! [Re: headhunter] #616332
02/18/10 09:42 AM
02/18/10 09:42 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
I don't have a car in mind yet, but this is what I'll be working on when the temps start to rise again soon...
Re: Let's see those Roots blower cars!!! #616333
02/18/10 05:00 PM
02/18/10 05:00 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
here it is with the small 850 carbs before the 1250's went on.
Post deleted by Defbob [Re: blownzoom440] #616334
02/18/10 05:18 PM
02/18/10 05:18 PM
Anonymous OP
Anonymous OP
Re: Let's see those Roots blower cars!!! #616335
02/18/10 05:42 PM
02/18/10 05:42 PM
ELYRIA,OH
ELYRIA,OH
Have you made any passes with the bigger carbs?
yes i have but only 3.i reduced the 10%OD to 10% UD and went .200 fsater spinning the tires off the line and 4MPH quicker.the idle fuel restriction was way too rich.Koffels drilled some blank jets for me at the track but it was not enough and i ran out of time.i am putting the internal parts into a KP440 and may go on the dyno this spring before it goes back in the car.the nay sayers about koffels dyno #'s should have fun with that.iether way it will be interesting.i will pulley up to the 10% OD on the dyno forsure and may go 20% depending on how things go.20% will be about 16 or 17 lbs of boost with my small heads.
Re: Let's see those Roots blower cars!!! #616336
02/18/10 08:51 PM
02/18/10 08:51 PM
Orlando Florida
blown572dart Offline
Orlando Florida
Not a roots but
Re: Let's see those Roots blower cars!!! [Re: blown572dart] #616337
02/18/10 09:37 PM
02/18/10 09:37 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
That's an itty bitty pulley. You wouldn't happen to be a wee bit overdriven would you?
- Stu Harmon
Re: Let's see those Roots blower cars!!! [Re: blown572dart] #616338
02/18/10 11:05 PM
02/18/10 11:05 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Not a roots but
Looks like a blower Nobody will know what's under the cover
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Post deleted by Defbob [Re: blownzoom440] #616339
02/19/10 12:35 AM
02/19/10 12:35 AM
Anonymous OP
Anonymous OP
Re: Let's see those Roots blower cars!!! #616340
02/19/10 03:16 AM
02/19/10 03:16 AM
ELYRIA,OH
ELYRIA,OH
4mph is a good improvement, especially if you slowed the blower down. To clean up the idle, you'll need to reduce the size of the idle feed restrictions by about 50%. That's one of the things Quick Fuel did to my 1150's. I can't find the calibration sheets that came with them, but if I run across them, I can scan them and send them to you, for reference. I know yours are 1250's, but it'll get you a lot closer to optimum than you are now.
Now that you have a rock solid block, we here at Moparts will expect you to run those OD pulleys at the track, not just on the dyno!
if you can find the data sheet that may help a lot and would be great!we opened up the IFR from 50 to 55 i believe and for as little as it did i think i need to go to a 70.the idle screws are only turned out 1/4 turn and is still making the plugs black but is reduced some.i ran 10% OD at the track also as in the video on the dyno.
Re: Let's see those Roots blower cars!!! #616341
02/19/10 04:22 PM
02/19/10 04:22 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Here you go...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Let's see those Roots blower cars!!! [Re: W.I.N. Racing] #616342
02/19/10 04:30 PM
02/19/10 04:30 PM
Byron, NY
Byron, NY
Another
'60 Willys CJ5
Re: Let's see those Roots blower cars!!! [Re: W.I.N. Racing] #616343
02/19/10 04:31 PM
02/19/10 04:31 PM
Byron, NY
Byron, NY
last one
'60 Willys CJ5
Re: Let's see those Roots blower cars!!! [Re: W.I.N. Racing] #616344
02/19/10 08:23 PM
02/19/10 08:23 PM
hemi-itis Offline
hemi-itis  Offline
Here you go...
Tell us more about that killer bullitt
Re: Let's see those Roots blower cars!!! [Re: hemi-itis] #616345
02/19/10 09:39 PM
02/19/10 09:39 PM
Byron, NY
Byron, NY
Just your basic 525 Blown/inj KB, Hemi,Veney heads,Venolia pistons, Brooks 88 rods, Bryant Crank, Cassel gear drive mike Kuhl 1471 std helix Blower,RCD Belt gaurd and crank suport. The motor made 2975ish Hp(high Helix blower) but I hope I have it detuned to around 1800.( small mag,.090 thick head gaskets[10.75-1 comp] std helix blower 20% overdriven, small pump [1100-1 Enderle] )
The motor is backed by a API 2 spd with bolt together 10" lock up converter. Dana 60, floater, all strange internals, w/4.10's.
The motor is nothing exotic, std Blown Alc parts(leftover A/FC stuff) no junk parts just not the "newest" There's enough motor there to go into the 6's just not enough wallet... I plan on putzing around in the 7sec area maybe in the future stepping up for deeper numbers.
The truck has been semi done for a while but customer cars always come first.. Was a slow year last year so I had time to finish it (again) Hope to be out early summer. Getting close, I ordered a new /15 fire suit today so I'm running out of reasons not to get it out there.
'60 Willys CJ5
Re: Let's see those Roots blower cars!!! [Re: W.I.N. Racing] #616346
02/19/10 10:28 PM
02/19/10 10:28 PM
hemi-itis Offline
hemi-itis  Offline
Sweeeet truck Guess ya don't street drive it
Re: Let's see those Roots blower cars!!! [Re: hemi-itis] #616347
02/19/10 10:43 PM
02/19/10 10:43 PM
Byron, NY
Byron, NY
Nope...
'60 Willys CJ5
Page 1 of 3 1 2 3
