Post deleted by Defbob
#616328
02/17/10 10:13 PM
02/17/10 10:13 PM
Re: Let's see those Roots blower cars!!!
#616329
02/18/10 03:20 AM
02/18/10 03:20 AM
Posts: 6 everywhere
stonecold
everywhere
[Re: blownzoom440]
#616334
02/18/10 05:18 PM
02/18/10 05:18 PM
[Re: blownzoom440]
#616339
02/19/10 12:35 AM
02/19/10 12:35 AM
#616340
02/19/10 03:16 AM
02/19/10 03:16 AM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
here it is with the small 850 carbs before the 1250's went on.
Have you made any passes with the bigger carbs?
yes i have but only 3.i reduced the 10%OD to 10% UD and went .200 fsater spinning the tires off the line and 4MPH quicker.the idle fuel restriction was way too rich.Koffels drilled some blank jets for me at the track but it was not enough and i ran out of time.i am putting the internal parts into a KP440 and may go on the dyno this spring before it goes back in the car.the nay sayers about koffels dyno #'s should have fun with that.iether way it will be interesting.i will pulley up to the 10% OD on the dyno forsure and may go 20% depending on how things go.20% will be about 16 or 17 lbs of boost with my small heads.
4mph is a good improvement, especially if you slowed the blower down. To clean up the idle, you'll need to reduce the size of the idle feed restrictions by about 50%. That's one of the things Quick Fuel did to my 1150's. I can't find the calibration sheets that came with them, but if I run across them, I can scan them and send them to you, for reference. I know yours are 1250's, but it'll get you a lot closer to optimum than you are now. Now that you have a rock solid block, we here at Moparts will expect you to run those OD pulleys at the track, not just on the dyno!
if you can find the data sheet that may help a lot and would be great!we opened up the IFR from 50 to 55 i believe and for as little as it did i think i need to go to a 70.the idle screws are only turned out 1/4 turn and is still making the plugs black but is reduced some.i ran 10% OD at the track also as in the video on the dyno.
#616341
02/19/10 04:22 PM
02/19/10 04:22 PM
Posts: 2,110 Byron, NY
W.I.N. Racing
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#616342
02/19/10 04:30 PM
02/19/10 04:30 PM
W.I.N. Racing
Byron, NY
[Re: W.I.N. Racing]
#616343
02/19/10 04:31 PM
02/19/10 04:31 PM
W.I.N. Racing
Byron, NY
[Re: hemi-itis]
#616345
02/19/10 09:39 PM
02/19/10 09:39 PM
W.I.N. Racing
Byron, NY
Just your basic 525 Blown/inj KB, Hemi,Veney heads,Venolia pistons, Brooks 88 rods, Bryant Crank, Cassel gear drive mike Kuhl 1471 std helix Blower,RCD Belt gaurd and crank suport. The motor made 2975ish Hp(high Helix blower) but I hope I have it detuned to around 1800.( small mag,.090 thick head gaskets[10.75-1 comp] std helix blower 20% overdriven, small pump [1100-1 Enderle] ) The motor is backed by a API 2 spd with bolt together 10" lock up converter. Dana 60, floater, all strange internals, w/4.10's. The motor is nothing exotic, std Blown Alc parts(leftover A/FC stuff) no junk parts just not the "newest" There's enough motor there to go into the 6's just not enough wallet... I plan on putzing around in the 7sec area maybe in the future stepping up for deeper numbers. The truck has been semi done for a while but customer cars always come first.. Was a slow year last year so I had time to finish it (again) Hope to be out early summer. Getting close, I ordered a new /15 fire suit today so I'm running out of reasons not to get it out there.
[Re: hemi-itis]
#616347
02/19/10 10:43 PM
02/19/10 10:43 PM
W.I.N. Racing
Byron, NY
[Re: RTSrunner]
#616349
02/19/10 11:17 PM
02/19/10 11:17 PM
W.I.N. Racing
Byron, NY
Thanx, Nope, all fiberglass...
[Re: W.I.N. Racing]
#616350
02/19/10 11:21 PM
02/19/10 11:21 PM
W.I.N. Racing
Byron, NY
[Re: 23T Hemmee]
#616360
02/27/10 03:08 PM
02/27/10 03:08 PM
Posts: 637 West Central Wi.
1969 HEMI R-T
West Central Wi.
Here is mine. Street car, 1969 Coronet R/T. origional 440 4 spd. now a hemi, engine was out of a pulling tractor. (early 80's) was rebuilt in 1987, been in there since. has aluminum rods, roller cam. fun car!
HEMI,S ARE FOREVER!!!
[Re: 1969 HEMI R-T]
#616363
02/27/10 03:20 PM
02/27/10 03:20 PM
1969 HEMI R-T
West Central Wi.
#4 I am putting the novi 2000 on the 4 dr. stock 318. I have it apart now, hope to get time before to long to get it running. I have it on there, but need a boost elbow, and the carb yet, and some misc parts. I am going to waite for the innercooler till next winter. I will post some pics when I can get some.
[Re: 1969 HEMI R-T]
#616364
02/27/10 07:56 PM
02/27/10 07:56 PM
blownzoom440
ELYRIA,OH
i noticed you have a lot of rear tilt to the engine.
[Re: blownzoom440]
#616365
02/27/10 10:36 PM
02/27/10 10:36 PM
1969 HEMI R-T
West Central Wi.
my hemi is on stock motor mts. OE parts I have noticed this on other cars also! every thing fits very well!
[Re: 1969 HEMI R-T]
#616366
02/28/10 08:11 PM
02/28/10 08:11 PM
Posts: 329 N.Y.
VZCharger
N.Y.
Here's mine. Has had a blower motor since the late 90's.
70 Charger blown injected BB
07 Charger Daytona Plum Crazy #389
69 Coronet ragtop
96 Ram "Garlits Edition"
88 Conquest TSi
[Re: VZCharger]
#616368
02/28/10 08:12 PM
02/28/10 08:12 PM
Posts: 329 N.Y.
VZCharger
N.Y.
