Re: lost oil pressure [Re: rowin4] #616086
02/21/10 07:51 AM
02/21/10 07:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Glad to hear you got it squared away Steve
Re: lost oil pressure Found the problem [Re: rowin4] #616087
02/21/10 10:11 AM
02/21/10 10:11 AM
NC
440Jim Offline
440Jim  Offline
NC
I had an oil pressure gauge break in the staging lanes when I started the car to go to the water box. Pulled off to the side. I took off the oil pressure line at the back of the block (1/8 tubing) and cranked it over... oil shot out over the fender! A fellow racer gave me a spare gauge and it all checked out fine. Went to eliminations that day and made it to 5th round.
Re: lost oil pressure Found the problem [Re: 440Jim] #616088
02/21/10 10:17 AM
02/21/10 10:17 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Was it pretty obvious ?,,,ie,,was it loose when you found it ?
glad to hear you got it fixed....
Re: lost oil pressure Found the problem [Re: rowin4] #616089
02/21/10 10:43 AM
02/21/10 10:43 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
great I'm going to be removing the valve and spring on the 572 to adjust the pressure I will add a drop of loctite as well.
Re: lost oil pressure Found the problem [Re: 69CHARGERMD] #616090
02/21/10 12:08 PM
02/21/10 12:08 PM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
[/quote
Yes it was when I removed the cover, I didn't look up into that area before to look at it. Another turn it would have popped out. Left the pump on the block ,just removed the rotor and ring, inspected, greased them up and reassembled.
