Re: lost oil pressure Found the problem
[Re: 69CHARGERMD]
#616090
02/21/10 12:08 PM
02/21/10 12:08 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Was it pretty obvious ?,,,ie,,was it loose when you found it ? glad to hear you got it fixed.... [/quote
Yes it was when I removed the cover, I didn't look up into that area before to look at it. Another turn it would have popped out. Left the pump on the block ,just removed the rotor and ring, inspected, greased them up and reassembled.
