Small block super gas mileage intake? #615956
02/17/10 07:36 PM
02/17/10 07:36 PM
North Central Florida
E
eightlitermopar Offline OP
E
Ok, I just picked up an intake for my small block 4 door coronet
1969 coronet four door granny car
318 (currently little 2bbl intake)
I have been fighting with the carb, so I have opted to go with a four barrel.
I just picked up and intake for $50, but I don't know much about it.
CASTING S.P.2.-P. 318
From what I have read, this is a low performer intake, but I think it will work great with my non performance 318.
I will be upgrading the cam to a comp stick with .425/.425 lift and adding a 600 cfm carb on top. Should I go one step bigger on the cam?
Any input about this intake and my setup? Thanks in advance.
eight
Mopar or no car
Re: Small block eddy intake ID help! [Re: eightlitermopar] #615957
02/17/10 08:41 PM
02/17/10 08:41 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
the SP2P is a "emissions" manifold produced in the mid 70s. it has the 318 ports and works ok to about 4500 RPM. use a 600/625 CFM carb....
good luck
I am truckless..
Re: Small block eddy intake ID help! [Re: eightlitermopar] #615958
02/17/10 11:13 PM
02/17/10 11:13 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
You might want to rethink the S.P.2.P swap. The ports are actually SMALLER than a stock 318 2 barrel by a noticeable margin. A stock 1973-up iron intake is a far better choice. It only weighs a few lbs more than the 2 barrel intake. The S.P.2.P is okay for a totally stock 318 that rarely exceeds 3000 rpms.
Re: Small block eddy intake ID help! [Re: Kern Dog] #615959
02/18/10 12:01 AM
02/18/10 12:01 AM
E
E
that would figure since I picked up the intake today for $50. I'll keep an eye out for some iron manifolds in my area, I am kind of on a tight budget.
So, this intake would actually hurt my granny 4 door 318 compared to the 2 bbl that is on it now even if I increased the cam lift and duration some?
thanks again guys
eight
Mopar or no car
Re: Small block eddy intake ID help! [Re: eightlitermopar] #615960
02/18/10 12:28 AM
02/18/10 12:28 AM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
no; in normal daily driver duty that SP 2P will be fine. Amall ports for better velocity. I've had that intake, I would use another if I got it.
the one I would like to find/try is an LD4B.
Re: Small block eddy intake ID help! [Re: volaredon] #615961
02/18/10 12:51 AM
02/18/10 12:51 AM
E
E
Thanks for the little bit of light throught the dark clouds I figured I was completely screwed with my new intake! Did you see and increase in gas mileage with this intake?
Anyone suggestions on cam choice for this motor with this intake? I was thinking either
Comp 252H .425/.425 lift with 206* of duration
Comp 260H .440/.440 lift with 212* of duration
thanks for any input!
eightlitermopar
Mopar or no car
Re: Small block super gas mileage intake? [Re: eightlitermopar] #615962
02/18/10 01:15 AM
02/18/10 01:15 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
I am a SP2P fan ... and in direct reference to the topic at hand .. there is no better intake for mpg and throttle-response on a stocker-type motor.
To label this intake an "emissions" piece is not really correct .. it is emissions "legal". And YES .. the ports are very small ...to get the best A/F velocity ... for the best atomization. Because of these small ports .. the intake is "dead" over 4200 rpms or so.
IN CASE anyone is interested ... a pic is attached that shows the diff between a stock size B/RB port and a RB SP2P intake.
When I get the rear-end gear changed to a 3.73 in my motorhome .. I will be putting one of these on the 413. Presently I am running a Streetmaster intake. GOOD piece .. but for higher rpm usage(with the 4.56 gear now).
Re: Small block super gas mileage intake? [Re: dOoC] #615963
02/18/10 02:04 AM
02/18/10 02:04 AM
hooziewhatsit Offline
I have an SP2P on my truck 318, with an eddy 1406 and Lunati 60400 cam. Never taken it over about 3300 rpms.
Oh, and get the fel pro composite intake gaskets, and some thread sealer the intake bolts. I tried the paper/tin ones twice
Re: Small block super gas mileage intake? [Re: hooziewhatsit] #615964
02/18/10 02:32 AM
02/18/10 02:32 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yep those intakes are made for port velocity. That equals good throttle response and mpg.
Re: Small block eddy intake ID help! [Re: eightlitermopar] #615965
02/18/10 08:52 AM
02/18/10 08:52 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
eightlitermopar
lunati voodoo 60400, use comp #901 valve springs.
for an intake, I'd find a used eddie performer, can usually find them for under $100.
2017 Grand Cherokee Overland
Re: Small block eddy intake ID help! [Re: patrick] #615966
02/18/10 02:47 PM
02/18/10 02:47 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Don't waste your $ on the 252; I was looking around; compare the specs to a STOCK 360-2 bbl (or only 360 cam, in the 80s truck) cam; other than being 0.015" less lift at the valve (big whup, with your intended use) that cam is dang near identical to the 252. I bought a 360 stock replacement cam for the 318 in my 3/4 ton truck; for $76 vs $145 that 0.015 means nothing. and yes it did make a difference in how my truck runs, hauls, tows.
It is an improvement over the OE 318 cam for sure, but with the 252 all you pay for is the name...... COMP! Duration overlap etc., are dang near identical from what I saw listed for the 252.
Re: Small block eddy intake ID help! [Re: volaredon] #615967
02/18/10 03:51 PM
02/18/10 03:51 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
advertised duration is similar, but if you look at some of the other timing events, it's not. IIRC a stock 360 cam is ~190-195 degrees duration at .050, or 10-15 degrees smaller than the 252. I bet .2" duration is even greater of a difference.
Re: Small block eddy intake ID help! [Re: patrick] #615968
02/18/10 04:23 PM
02/18/10 04:23 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
If I were building a 318 for mileage it would have to have a zero deck piston for good quench (like the KB), the late model #302 casting heads (cheap to find) with a little bowl work and a slightly ported SP2P and a 600 holley vacuum with the old redline/weber 3 circuit metering block and a lock-up 998 trans or a manual od 833 with a final drive ratio of around 2.94. The cam would be the old Cam Dynamics 252 which was (IIRC) around 206 @.050, .440 lift single pattern on 112 centers or even the factory 360 2 bbl cam (.410 lift.)
The sp2p was really a great concept, it's just that the port cross section was made about 10% too small...which made it detonation prone at high load and part throttle with 70's style emissions, it'd be perfect on a 273 built the same way.....I'm thinking I could build a 273 that would pull 65mph at less than 2000rpm and get at least high 20's mpg in an A body....or about the same as a 90's era Maxima v6. Keeping it very cool (like under 175 degrees) will go a long way to making the combo work on pump gas too.
I've been looking for an sp2p to play with for such a project.
the LA motor is one of the most fuel efficient v8s made for its time
WIZE
In Car:
Re: Small block eddy intake ID help! [Re: Streetwize] #615969
02/18/10 07:01 PM
02/18/10 07:01 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
I've always had good luck with the stock 340 style cams
Re: Small block eddy intake ID help! [Re: DusterKrazy] #615970
02/18/10 09:21 PM
02/18/10 09:21 PM
E
E
thanks for the reply guys! I know this is a hobby, but some things I hate to do twice (like put a manifold on a small block while in the car!)
So here is a scenerio.
As I currently stated, I currently have the 1969 318 motor with the stock cam (approx .400 lift from what I have read)
the two barrel works, but it does leak and it's not running it's best.
What could I expect if I simply put on this sp2p manifold with an eddy 600 cfm carb (adjusted properly of course for elevation).
If I changed nothing else, and simply did this change, what would I see? Decrease in power? Would the carb be too much fuel and flood or cause detonation to blow up my motor? Would I pull the front tires off the ground when accelerating ok, I am not really expecting that.
Simple carb and intake swap, nothing else. What would I expect?
thanks!!!
Mopar or no car
Re: Small block eddy intake ID help! [Re: eightlitermopar] #615971
02/18/10 10:37 PM
02/18/10 10:37 PM
Manitoba, Canada
Manitoba, Canada
Expect a small mid-upper rpm power increase. The stock 318 heads/cam are both so small that really any 4bbl intake will do.
Re: Small block eddy intake ID help! [Re: DaytonaTurbo] #615972
02/20/10 04:39 PM
02/20/10 04:39 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
My says to put a holley 500 cfm 2 barrel on what you have and be surprised by throttle response and gas mileage of a properly tuned carb. I ran this combo on a 70 dart with 318 and stock 2 barrel intake with 2.94 road gear and got 20+ mpg. Any changes to the amount of air you put into the chamber is gonna = less fuel economy in most every case. At least that is the way I figure if you are gonna keep the fuel air ratio at optimum.
Re: Small block eddy intake ID help! [Re: Streetwize] #615973
02/20/10 05:31 PM
02/20/10 05:31 PM
Streetwize wouldn't a hotter stat help economy by giving better atomization/less puddling in cold weather?
Re: Small block eddy intake ID help! [Re: RapidRobert] #615974
02/20/10 05:57 PM
02/20/10 05:57 PM
dulcich Offline
dulcich  Offline
SP2P works really well on a 318 with stock heads. I would use a 600 Holley or TQ. It will be a huge power gain over the two barrel - almost an unbelievable gain - and it will get better mileage too. You can expect the engine to keep pulling strong to about 5000 rpm.
-dulcich
Re: Small block eddy intake ID help! [Re: dulcich] #615975
02/20/10 07:29 PM
02/20/10 07:29 PM
Kansas
racincuda Offline
racincuda  Offline
Kansas
I had a SP2P on a 318 w Holley spredbore and a 360 cam
Engine made good low and mid range power, ran hard to about 5000 rpm
If I did it again I would go for more cam but thats just me and my
