sb roller lifter help oiling #615885
02/17/10 06:47 PM
02/17/10 06:47 PM
CA.
RAY1969CARS Offline OP
CA.
hi gays when putting a roller lifter in a small block "solid roller" do you have to restrict oil for all lifters???? std block dos any one make a solid roller lifter that you done have to do this????? im putting a 620 lift cam thanks guys!!!
Re: sb roller lifter help oiling [Re: RAY1969CARS] #615886
02/17/10 07:22 PM
02/17/10 07:22 PM
ohio
flynbyu Offline
flynbyu  Offline
ohio
I used the comp 828-16 with a .570 lift cam with no tubes in a 340.but you have to grind the lifter valley to clear the lifters and the cross bars..
Re: sb roller lifter help oiling [Re: flynbyu] #615887
02/17/10 10:58 PM
02/17/10 10:58 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
Drop the 828's in and go. No other work here and ran fine for years.
