Cam Break In Procedures... #615797
02/17/10 04:10 PM
02/17/10 04:10 PM
MD.
V
vttm Offline OP
vttm  Offline OP
V
MD.
I am currently building a 440 with eddy heads and would like to use a solid flat tappet cam " not sure yet of manufacturer" but somewhere in the .620 to .630 lift range. While searching for a cam I see that a lot of companys are recomending that during break in to remove the inner spring is this something that is has to be done or is this overkill. My springs are 145lbs @ seat and 380lbs @ 600 lift.
Re: Cam Break In Procedures... [Re: vttm] #615798
02/17/10 04:20 PM
02/17/10 04:20 PM
PA
ajcasini Offline
ajcasini  Offline
PA
I have not done this in the past with cams and springs around that lift. What I do is run the Brad Penn Break in oil with the comp cams additive. I am not an engine builder but have done 3 motors for myself and that is the procedure that I used and had no problems.
Re: Cam Break In Procedures... [Re: ajcasini] #615799
02/17/10 04:30 PM
02/17/10 04:30 PM
organ
maximum entropy Offline
organ
same here.
Re: Cam Break In Procedures... [Re: maximum entropy] #615800
02/17/10 08:24 PM
02/17/10 08:24 PM
MD.
V
vttm Offline OP
vttm  Offline OP
V
MD.
Thanks for the info. Anyone else have any opinions?
Re: Cam Break In Procedures... [Re: vttm] #615801
02/17/10 08:36 PM
02/17/10 08:36 PM
UK
602heavy Offline
602heavy  Offline
UK
I would'nt bother removing inner springs @ those pressures , plenty lube on cam & base of lifters with some zinc additive , just remmember not to use assembly lube on lifter/bore , you want those lifters spinning on fire up.
Re: Cam Break In Procedures... [Re: vttm] #615802
02/17/10 09:29 PM
02/17/10 09:29 PM
CT: Corrupticut
Mr71Bee Offline
Mr71Bee  Offline
CT: Corrupticut
IMO...Why take the chance? Its easy to install the inners after you break it in. Plus, you have to have it half apart to retorque the heads anyway.
Re: Cam Break In Procedures... [Re: vttm] #615803
02/19/10 03:13 PM
02/19/10 03:13 PM
Forest Grove,Oregon
beepbeepdon Offline
beepbeepdon  Offline
Forest Grove,Oregon
Give Dave Hughes a call @ Hughes Engines 309.745.9558. He and his staff have really helped me. I bought most of my config from him including a.614" solid flat tappet using Hughes 1.6 roller rocker setup.He has a break-in oil as well.
Re: Cam Break In Procedures... [Re: Mr71Bee] #615804
02/19/10 03:20 PM
02/19/10 03:20 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
I agree with this...we use our engine stand to break in engines so everything is easy access anyway, so installing the inner springs afterwards is a piece of cake. And we still use the break in oil and additives. With the large amount of wiped out cams you hear about nowadays I believe in overkill.
Peace of mind and not having to clean metal out of an engine with a wiped cam=priceless.
Re: Cam Break In Procedures... [Re: dustergirl340] #615805
02/19/10 03:42 PM
02/19/10 03:42 PM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
Your cam selection is determinate here. That lift is kinda like 1/2 a loaf. If you pick one with a very aggressive lobe profile, there may be issues.
A friend picked a cam with aggressive lobes and wiped it. Next time removed inner spring and broke in w/o issues. BTW same spring pressures as you. So I'd also be looking at high quality lifters as well. Just my take
Re: Cam Break In Procedures... [Re: BELVEDERE67] #615806
02/19/10 03:48 PM
02/19/10 03:48 PM
Peoples republic of clackamas ...
atoetly Offline
atoetly  Offline
Order a set of these and don't worry about it again. http://www.4secondsflat.com/Composite%20lifters.htm
Re: Cam Break In Procedures... [Re: dustergirl340] #615807
02/19/10 03:51 PM
02/19/10 03:51 PM
MD.
V
vttm Offline OP
vttm  Offline OP
V
MD.
Thanks for all the advice. I am leaning towards the better safe than sorry side because I have heard all the horror stories. I was just trying to get by with a little less work. The only reason I havent called Hughes is that I understand to run one of their cams you have to use their springs and my heads are currently set up with new springs.
Re: Cam Break In Procedures... [Re: atoetly] #615808
02/19/10 03:52 PM
02/19/10 03:52 PM
Europa, Estonia
Georg Offline
Georg  Offline
Europa, Estonia
That`s right!
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: Cam Break In Procedures... [Re: vttm] #615809
02/19/10 04:12 PM
02/19/10 04:12 PM
NC
440Jim Offline
440Jim  Offline
NC
I would never even think of breaking in a new cam with those springs. Don't take the chance, do everything you can to avoid wiping a lobe/lifter during break-in.
The results of a wiped cam is worse than the work to change the springs after break-in. Complete engine disassembly and cleaning, new bearings, potential cylinder/piston scoring, etc.
Re: Cam Break In Procedures... [Re: atoetly] #615810
02/19/10 04:23 PM
02/19/10 04:23 PM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
Yes I have the original Schubecks in mine so there really is no breakin. I'd recommend them as well, but it's really hard to write that check. I did and am glad I did. Not sure it's in everyones budget.
Re: Cam Break In Procedures... [Re: BELVEDERE67] #615811
02/19/10 04:37 PM
02/19/10 04:37 PM
MD.
V
vttm Offline OP
vttm  Offline OP
V
MD.
Are the Schubecks any taller or shorter than a normal lifter?
Re: Cam Break In Procedures... [Re: vttm] #615812
02/19/10 05:17 PM
02/19/10 05:17 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
I have also removed the inner springs to break my cam in, cam and lifters cost to much these days to risk it.
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: Cam Break In Procedures... [Re: vttm] #615813
02/19/10 05:32 PM
02/19/10 05:32 PM
Az
Crizila Offline
Crizila  Offline
Az
I didn't do it on a .615" lift cam and ate up a lobe - zinc additive and all. I now do it. Lots of extra work, but the alternative really sucks.
Fastest 300
Re: Cam Break In Procedures... [Re: vttm] #615814
02/20/10 11:45 AM
02/20/10 11:45 AM
atoetly Offline
atoetly  Offline
The lifters shouldn't be any different than stock lifters unless you have them custom made. Do you have more info on those springs? If your going with a cam with 630 lift you might put yourself into a coil bind situation and that will break parts and flatten cams. I know that the sm lifters are expensive but the cost of wiping a cam is triple the amount of the lifters and they are completely reusable on other cams.
Re: Cam Break In Procedures... [Re: atoetly] #615815
02/20/10 12:15 PM
02/20/10 12:15 PM
MD.
V
vttm Offline OP
vttm  Offline OP
V
MD.
The springs are 1.880 install height @ 145lbs and 380 lbs @ 600 lift and 1.200 coil bind height.
Re: Cam Break In Procedures... [Re: vttm] #615816
02/20/10 12:49 PM
02/20/10 12:49 PM
atoetly Offline
atoetly  Offline
with .630 lift that gives you a theorectical clearance of .050 before coil bind. I don't like running something that close but may be OK? Others may way in on coil bind or start another thread pretaining to it?
