Re: Cam Break In Procedures...
[Re: Mr71Bee]
#615804
02/19/10 03:20 PM
02/19/10 03:20 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
IMO...Why take the chance? Its easy to install the inners after you break it in. Plus, you have to have it half apart to retorque the heads anyway.
I agree with this...we use our engine stand to break in engines so everything is easy access anyway, so installing the inner springs afterwards is a piece of cake. And we still use the break in oil and additives. With the large amount of wiped out cams you hear about nowadays I believe in overkill.
Peace of mind and not having to clean metal out of an engine with a wiped cam=priceless.
[Re: vttm]
#615809
02/19/10 04:12 PM
02/19/10 04:12 PM
Posts: 16,931 NC
440Jim
NC
My springs are 145lbs @ seat and 380lbs @ 600 lift.
I would never even think of breaking in a new cam with those springs. Don't take the chance, do everything you can to avoid wiping a lobe/lifter during break-in.
The results of a wiped cam is worse than the work to change the springs after break-in. Complete engine disassembly and cleaning, new bearings, potential cylinder/piston scoring, etc.
[Re: vttm]
#615812
02/19/10 05:17 PM
02/19/10 05:17 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
I have also removed the inner springs to break my cam in, cam and lifters cost to much these days to risk it.
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: vttm]
#615814
02/20/10 11:45 AM
02/20/10 11:45 AM
Posts: 1,226 Peoples republic of clackamas ...
atoetly
Are the Schubecks any taller or shorter than a normal lifter?
The lifters shouldn't be any different than stock lifters unless you have them custom made. Do you have more info on those springs? If your going with a cam with 630 lift you might put yourself into a coil bind situation and that will break parts and flatten cams. I know that the sm lifters are expensive but the cost of wiping a cam is triple the amount of the lifters and they are completely reusable on other cams.
