Re: Windshield Installation
[Re: riverman]
#615251
02/17/10 03:33 PM
02/17/10 03:33 PM
340dart4spd
Parts Problem
Parts Problem
Replacing the windshield on the 69 GTX. Have the Soft Seal windshield gasket for it. Now evidently I need a tear shaped lockstrip to lock the glass in. Any body know who carries this? Also what do I need underneath the gasket - 5/16 inch tape (and who carries that) or a tube sealant? I am not going to change in the glass (although the old one is now out), just to have everything ready for the installer. Thanks in advance.
I use a brush on sealer..and in the lower corners use the the tube type..
[Re: riverman]
#615252
02/17/10 04:25 PM
02/17/10 04:25 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
Are you sure you need a "filler" type of lock strip or does your WS gasket have a "self" lock strip... Seems like it was A bodies that had the filler strip lock.....
[Re: minivan]
#615253
02/17/10 04:35 PM
02/17/10 04:35 PM
340dart4spd
Parts Problem
Parts Problem
68 up should not need locking strip..
67 is diff...
[Re: 340dart4spd ]
#615255
02/17/10 06:06 PM
02/17/10 06:06 PM
Posts: 33 Eastern North Carolina
riverman
Thanks all for your responses. On another forum a guy from Australia has a 69 Charger and directed me to look at the seal closer. Yes there is a rubber flap that bends over into the channel and locks the glass, so it is self sealing. I got confused as the old gasket (either original or replacement some time back has the tear shaped lock strip. I called Soft Seal this morning and their tech center guy was clueless. So again thanks for the confirmation. By the way, anyone install this windshield by putting the seal on the pinch weld first and then putting in the glass? This what Australia says. No jokes about being upside down.
