70 GTX trim clips #615229
02/17/10 09:48 AM
02/17/10 09:48 AM
Fort Wayne,Indiana 46845
mopar 394 Offline OP
What clips does the 70 gtx use for the stainless trim that outlines the back trunk/finish panel area? Where can I buy these? Thanks, Todd
Re: 70 GTX trim clips [Re: mopar 394] #615230
02/21/10 10:39 AM
02/21/10 10:39 AM
Shrewsbury, MA
70_GTX_SIXPACK Offline
Shrewsbury, MA
RT Specialties has the plastic clips... Good luck on getting the parts in a timely fashion... Took forever to get mine.
Re: 70 GTX trim clips [Re: 70_GTX_SIXPACK] #615231
02/21/10 11:09 AM
02/21/10 11:09 AM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
the trim that on the uper of the trunck lip metro sell a kit 2 clips w/stud & nut and a roll of twoway tape
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: 70 GTX trim clips [Re: 1969gtx] #615232
02/22/10 02:13 AM
02/22/10 02:13 AM
California
70SportSatellite Offline
super street
super street
California
this is correct. the two outer curved pieces use metal clips that slide into the3 molding and then snap into the holes of the quarter panel extensions. the piece that runs across the upper edge of the deck lid is sedured at the ends with two very special clips with buit in studs that anchor the trim to the edges of the deck lid with nuts. I have never seen these used anywhere else. double sided tape is used to secure the remainder of the trim to the lid. Originally I believe this was black and maybe a 1/16th of an inch thick. I was able to hunt down some tape that was much thinner and clear which I prefer over the original. I think I got it from 3m and had to order it.
