Re: Anyone use Summits Urethane Paint?
[Re: 36PLYM]
#615208
02/17/10 02:49 PM
02/17/10 02:49 PM
Posts: 708 Mechanic Falls, Maine
4BBodies
mopar addict
mopar addict
![](/ubbthreads/images/graemlins/iagree.gif) with Mopargnome, what you shoot is pretty much the final look with single stage metallics. Usually you put on your 2 or 3 medium/heavy coats, and then mist a light coat quickly across your original pattern, to get rid of any stripes in the metallic. If you wait too long it dulls it, if you do it too fast it runs. It has its uses however, I edge panels with it, and paint the car in base/clear coat. Or just pick a solid color, then you can do the whole car no problem. The best thing about solid colors and no experience is that you can fix mistakes (i.e. runs, sags, dirt, etc.) a lot easier!
[Re: 4BBodies]
#615211
02/17/10 04:11 PM
02/17/10 04:11 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
My neigbor just shot his AMX with single stage urethane(Limco)metallic and wet cut and buffed it and it turned out great.
[Re: 71 FJ6 Charger]
#615216
02/17/10 10:44 PM
02/17/10 10:44 PM
Posts: 403 NE Ohio
71 FJ6 Charger
NE Ohio
Adding reducer DOES help on or after your final coat,overall and when repairing/blending.
'71 383HP FJ6 Charger SE
#615217
02/17/10 11:21 PM
02/17/10 11:21 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
I am in no way a professional painter,but all I have ever used is single stage paints.I have painted maybe 5 or 6 cars with metallic and have never had a problem with striping. I shot my wife's Intrepid last summer with Summit's Dark Jade metallic,and like the paint.As I said,I'm not a pro,and I had a few problems because I finally went to an HVLP gun,but nothing that had to do with the actual paint. My opinion is,if you are on a tight budget,use it. If you have problems with it,it is cheap enough to buy more and "fix" your paint job.I would rather get the practice with less expensive materials,that's why I tried it on a daily driver with my new gun,before I do something I want to really look nice. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Dunnuck Racing]
#615218
02/17/10 11:59 PM
02/17/10 11:59 PM
Posts: 403 NE Ohio
71 FJ6 Charger
NE Ohio
I assumed HVLP. That is the basic it seems nowadays.
[Re: 440challenger]
#615220
02/18/10 05:47 PM
02/18/10 05:47 PM
Posts: 89 oregon
ramcharger1964
oregon
Do yourself a favor and go with a basecoat/clearcoat instead of a single stage. B/C is MUCH more forgiving and and easy to spray. With a good thick coat of high solids clear you can sand and buff out almost any imperfection and it will come out looking like you paid 10 grand for the paint job I also second the motion of using SPI - Southern Polyurethanes. They have absolutely outstanding products for a great price. You will not find better people to deal with!
Hell B!tch Racing Co.
