mixture distribution 440-3 and dominator #614966
02/16/10 09:30 PM
02/16/10 09:30 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
I am starting to get a handle on tuning my 3 circuit dominator midrange. Idle is good. Street cruising I have finally got the rear 6 plugs brown at 1500 to 3500. #1 and 2 plugs still sooty. Since running on just the front barrels at cruise with the plunge cut on the 440-3 intake, no spacer. It seems to over fuel the front 2 cylinders. I used the 440-3 for hood clearance. I have a 440-2 intake and tapered 2 inch spacer. I can run it with no air filter to try, or pull the hood. It looks like fuel and air would be directed more to the center with this combo, or am I way off base.
Re: mixture distribution 440-3 and dominator [Re: galen] #614967
02/16/10 10:32 PM
02/16/10 10:32 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I think you could still pull some more fuel out of it
If the plugs were black they will never clean the insulator to get a good reading.
If so put 1 new plug in a decent cylinder and chech that one after a road test. It'll save you $$$ in plugs.
Re: mixture distribution 440-3 and dominator [Re: galen] #614968
02/17/10 12:21 AM
02/17/10 12:21 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
#1 and 2 plugs still sooty... It seems to over fuel the front 2 cylinders.
And I'll bet the back 2 also at WOT.
I used the 440-3 for hood clearance...It looks like fuel and air would be directed more to the center with this combo, or am I way off base.
Look at it again, the divider ramps the fuel onto the ENDS of that manifold. Easiest fix would be to mill back the divider further. But, I would work the entire manifold plenium to equalize distribution. Adding a spacer will some help too.
Re: mixture distribution 440-3 and dominator [Re: HardcoreB] #614969
02/17/10 01:48 AM
02/17/10 01:48 AM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Thanks guys. I know I still need to pull some more fuel out of it. The plenum looks like a better design on the 440-2. Does anyone have pictures of modifications to the plenum on the 440-3? Thanks, Galen
