tunes in your vintage Mopar.......what are you using? #61339
05/22/08 12:08 AM
05/22/08 12:08 AM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
how about some pics and details of what you're running for car audio in your classic Mopar.
i'm in the process of putting my heap back on the road, and while i enjoy the sound of a healthy V8 as much as anyone......i kind of like to have the stereo cranking if i'm going any distance at all.
what are you guys using, and how much hacking did you have to do to install it?
Re: tunes in your vintage Mopar.......what are you using? [Re: fast68plymouth] #61340
05/22/08 12:46 AM
05/22/08 12:46 AM
Upper Midwest
Black_Sheep Offline
Black_Sheep  Offline
Upper Midwest
Stock AM/8 Track with 3 speaker dash. The radio has been upgraded with an MP3 player jack and better speakers, the "system" sounds pretty good for what it is...
'69 Plymouth GTX
See you on the street...
Re: tunes in your vintage Mopar.......what are you usin [Re: Black_Sheep] #61341
05/22/08 01:24 AM
05/22/08 01:24 AM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
Cherry bombs --
Re: tunes in your vintage Mopar.......what are you using? [Re: Black_Sheep] #61342
05/22/08 02:06 AM
05/22/08 02:06 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
alpine stereo, ipod hookup, polk audio speakers. i need a little 8" woofer or something to round the sound out. but sounds good!
Makes the long runs go by faster, Dad likes going to the pretty far car shows. (far with 3.91s) 150mile round trip last time. 'least i had some tunes
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: tunes in your vintage Mopar.......what are you using? [Re: GoodysGotaCuda] #61343
05/22/08 07:21 AM
05/22/08 07:21 AM
Indiana
Cuda_Mike Offline
Cuda_Mike  Offline
Indiana
Original am/fm radio in my 69 GTX, I hardly ever use the tape or cd players in my modern vehicles, radio is all I need...
Re: tunes in your vintage Mopar.......what are you using? [Re: Cuda_Mike] #61344
05/22/08 11:10 AM
05/22/08 11:10 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Right now the tunes in my old Mopars is the radio on my workbench......... That's what happens when everything is apart.
My GTS has the stock AM radio and will probably stay that way. My son's Dart has a modern CD player hidden in the glovebox with decent speakers. I will probably do something similar in my Barracuda.
Re: tunes in your vintage Mopar.......what are you using? [Re: Jim_Lusk] #61345
05/22/08 11:35 AM
05/22/08 11:35 AM
Canada
RobR Offline
RobR  Offline
Canada
I never really listen to the tunes but I put some in for my son..(I'm too busy listening for parts falling off)
Re: tunes in your vintage Mopar.......what are you using? [Re: RobR] #61346
05/22/08 11:47 AM
05/22/08 11:47 AM
Oklahoma
silverfish Offline
silverfish  Offline
Oklahoma
Is it just me or is something missing in this picture just to the right of the brake pedal???
Re: tunes in your vintage Mopar.......what are you using? [Re: silverfish] #61347
05/22/08 12:02 PM
05/22/08 12:02 PM
Berwyn, IL
challenger70 Offline
Berwyn, IL
I have an Eclipse head unit with Boston Acoustics speakers (3.5" in factory location and factory grilles) on the dash and 6x9 in the package tray. 2 Rockford Fosgate amps one for the sub one for the interior speakers and a JL Audio 10" Sub in the trunk. From inside/outside all you can see that is out of norm is the little red "Boston" on the speakers through the grills(if you really look) and the aftermarket head unit in the factory spot. But turn it on and it sounds unbelievable for a 40 year old dodge and puts most new cars to shame.
Re: tunes in your vintage Mopar.......what are you usin [Re: Hotwheelsjr] #61348
05/22/08 12:07 PM
05/22/08 12:07 PM
PORT ALBERNI B.C. CANADA
71DemonRON Offline
71DemonRON  Offline
Cherry bombs --
Re: tunes in your vintage Mopar.......what are you using? [Re: silverfish] #61349
05/22/08 12:16 PM
05/22/08 12:16 PM
Canada
RobR Offline
RobR  Offline
Canada
For some unknown reason my orig gas pedal wore out and broke I scored a new NOS pedal with the decor trim and I don't have the matching brake and clutch to go with it so I didn't put it in...
Re: tunes in your vintage Mopar.......what are you using? [Re: RobR] #61350
05/22/08 12:23 PM
05/22/08 12:23 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have an aftermarket radio that fit perfect right in the stock location. Thats all I would use as I wont cut on my dash. If you look real close you might see it. Look at the steering wheel center cap and then look just to the right of it and thats my radio. Hey it works and I can listen to my oldies while I cruise. Ron
Re: tunes in your vintage Mopar.......what are you usin [Re: fast68plymouth] #61351
05/22/08 01:02 PM
05/22/08 01:02 PM
WA 98043
thecarfarmer Offline
WA 98043
A buddy of mine had a stock AM in his '66 Coronet 500 with an FM convertor stashed in the glovebox. Worked for him.
For my pickup ('54), I've got a bunch of pretty good stuff (that's several years out-of-date, but was high end at the time).
Eclipse 5303 head unit for the glovebox (which works okay since the glovebox is in the middle of the dash, and the head unit comes w/ a remote).
I also have an old 10" MTX sub that I may try to make an under-seat enclosure for, or just upgrade to a newer style subwoofer with a lower 'q' factor that works in a small box, depending on whether I can get a big enough box stuffed under there.
I'll re-use my Aura component drivers. Best sound I could find (at the time) in the under-$1K speaker market - and I listened to the Diamond, Quart, etc. offerings.
Unfortunately, (due to theft) I don't have my 3 way 24 dB crosssover; I'll have to get another crossover - I'm a big fan of separate amps for tweeters and mids.
Advice: spend as much as you can afford on the mid and tweeter speaker drivers - they're where the magic is. If you go for coaxials, ones that have an aim-able tweeter are preferable. If they aren't set up to be bi-amped, cut the leads off the tweeters, and put some separate leads on 'em so you can run them from a separate amp. Subs aren't such a critical item - they've received SO much R&D over the last fifteen years that even relatively cheap ones are pretty good. A single 10" or 12" is usually sufficient for musical reproduction (and even moderately high-power BOOM) in a typical '60's sedan). Since I got out of the scene a few years ago, there's been a lot of work spent on getting a lot of sound out of a small speaker enclosure (one that won't eat your trunk).
Most passive crossover sets (ones between amp and speaker) are CHEAP, and most tweeters are crossed over at too low a frequency; this leads to 'spitty' vocals (especially female voices) at higher volumes) - active (between the source and the amps) crossovers and separate amps solve a lot of this.
Subwoofers are really important to musical reproduction. A lot of kids go overboard on them, and neglect the rest of the equation (BOOM, BOOM, BOOM, while the licence plate frame and trunk lid buzz...). One of the best - and many of the worst - sub setups I've heard were 'bandpass' subs. Off-the-shelf stuff is basically hit-or-miss here; usually the latter. Bandpass boxes should be custom tailored to the sub and car. A musclecar-era car is a great candidate for one, however, since there are often speaker cutouts in the parcel deck under the rear window where the sound can come thru. For myself, I'd build an enclosure onto the bottom of the package deck to mound a sub in a BP box to feed thru there. It'd save some trunk space; you'd hardly see it with the trunk open - but just a single driver tucked up towards the front of the trunk will suffice, as long as you have speaker grills in the package deck to allow the sound in.
Buy amps bigger than you need (i.e. 60-100 watts per channel for speakers that you'll run at 30-50 watts); turn the gain down a little, and you'll have tons of headroom. Also, you don't need high-end amps for casual listening. The little tiny bit of sonic nuance you'll pick up by going to a high end amplifier will be lost as soon as you fire the car's engine (ask how I know).
Buy a head unit based on features you like; they all have CD drives and tuner packs that are way better than you'll need - any $100 name brand unit is going to be fine. Go shopping at the stereo store and pick which one you'll like to use.
Also, unless you're running a really big bass amp, I wouldn't run out and put stiffening caps on its input. Any decent quality speaker wire and power wire should suffice - there is VERY little to be gained there other than making sure the conductors are sized appropriately to the power load.
Probably a little "TMI" for your question; if so, here's what I'd leave you with: Allocate half the budget to your speakers; choose a radio based on the features you like.
Good references: Car Stereo Review Magazine, crutchfield.com
-bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: tunes in your vintage Mopar.......what are you using? [Re: RobR] #61352
05/22/08 02:38 PM
05/22/08 02:38 PM
Berwyn, IL
Berwyn, IL
What mounting points did you use for the amp you mounted on the rear sear brace? Factory holes or did you drill? I had the same idea for my Challenger but there wasn't quite enough room to get at it easily. I plan on doing that once I get to that point with the Charger though. Nice clean install.
Re: tunes in your vintage Mopar.......what are you using? [Re: challenger70] #61353
05/22/08 04:48 PM
05/22/08 04:48 PM
Va. Beach, Va
69superbee383 Offline
Va. Beach, Va
Factory AM radio with a Realistic FM converter old school
77 Macho Power Wagon LWB factory 440 70 Coronet 440 N code 3 speed
Re: tunes in your vintage Mopar.......what are you using? [Re: 69superbee383] #61354
05/22/08 06:50 PM
05/22/08 06:50 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
Stock AM/FM/reverb/fader with upgraded speakers.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: tunes in your vintage Mopar.......what are you using? [Re: gamagoat6x6] #61355
05/22/08 07:19 PM
05/22/08 07:19 PM
central new york
pettyblue440 Offline
central new york
I had member bigmoneylewis restore an am radio for my challenger for a great price. I also have a fm converter that is going under the dash. Wish I knew at the time he could ad a mp3 player jack to it, I would've had that done too.
Re: tunes in your vintage Mopar.......what are you using? [Re: fast68plymouth] #61356
05/22/08 07:57 PM
05/22/08 07:57 PM
Toronto, ON
Shakey Offline
Shakey  Offline
Toronto, ON
Turnswitch took my AM radio, added an FM tuner and an MP3 jack without changing the stock look.
1969 Dodge Charger R/T SE - 440 AUTO
Re: tunes in your vintage Mopar.......what are you usin [Re: Shakey] #61357
05/22/08 08:06 PM
05/22/08 08:06 PM
MoreParts Offline
MoreParts  Offline
I have an AM 8-Track too. I have the old FM Converter cartridge but it doesn't work too well. My favorite trick is recording my CD's to 8-Track and popping them in when I want some more modern tunes. It sounds great and makes people scratch their head when they hear something new coming from an 8 Track cartridge.
Re: tunes in your vintage Mopar.......what are you usin [Re: MoreParts] #61358
05/22/08 08:47 PM
05/22/08 08:47 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
An aluminum headed 340 and a tunnel rammed Hemi are all I care to listen to.
